klkordzi | Started Her Up | ||
I got the 85 started tonight and was able to break in the cam. I changed the heads for aluminum from an 86, port matched the heads and intake, added 1.6 roller rockers, headers and an adjustable fuel pressure regulator. I also eliminated the air pump and EGR and switched over to an 88's smaller starter. I had a lot of cleaning to do and had a couple false starts. First was the distributer being 180 degrees off cause I was watching the exhaust rocker rather than the intake when i was setting top dead center. Then I had a bad oil leak from the two piece Summit timing chain cover that forced me to drop the pan and take the entire front of the engine back apart so i could go back to the original cover. It was all worth it though after it fired right up and I ran at 2000rpm to break in the cam without a problem or leak.
Posted on: 2009/10/20 0:35
biggrizzly | Re: Started Her Up | ||
Good job! I bet it feels great to have that behind you.
Posted on: 2009/10/20 1:06
pianoguy | Re: Started Her Up | ||
Congrats!!
Posted on: 2009/10/20 1:07
bogus | Re: Started Her Up | ||
Way to go!!!
Posted on: 2009/10/20 1:36
Matatk | Re: Started Her Up | ||
Excellent! So how's it run?????
Matthew |
Posted on: 2009/10/20 2:46
klkordzi | Re: Started Her Up | ||
I need to check the timing and make sure everything like the idle etc are all where they should be. The idle has a nice lope to it and best of all, no codes.
Posted on: 2009/10/20 10:27
Mekanic | Re: Started Her Up | ||
Good chit mang!!!
Posted on: 2009/10/20 11:00
BrianCunningham | Re: Started Her Up | ||
Must be a great feeling
Posted on: 2009/10/20 13:00
