turbotim23 | Are there any better locker units for the dana 44HD rearends? | ||
Hi I'm tring to rebuild a dana 44HD rearend this winter that I bought to replace the dana 36 in my 93 corvette. I was thinking of cyroing the stock posi housing but am wondering if I'd be better off just replacing it with a hiperformance one if there is a better one'. Thanks Tim
Posted on: 2009/12/7 21:26
vetteoz | Re: Are there any better locker units for the dana 44HD rearends? | ||
Posted on: 2009/12/7 22:39
CentralCoaster | Re: Are there any better locker units for the dana 44HD rearends? | ||
So it looks similar in operation to a Torsen type differential?
Looks like the best of both worlds of a locker and a differential. Nice! |
Posted on: 2009/12/8 0:01
BrianCunningham | Re: Are there any better locker units for the dana 44HD rearends? | ||
That's the one I want to run.
Looks like it's a little hard to get a hold of though. |
Posted on: 2009/12/8 23:03
turbotim23 | Re: Are there any better locker units for the dana 44HD rearends? | ||
Summit can get them , said 800.30 Good Luck Tim
Posted on: 2009/12/10 17:44
