302 user(s) are online (240 user(s) are browsing Forums)
Does it work?
Aboatguy Oreilly's full synthetic Oil change Special
My Avatar was redistributed!
498 Posts
Anybody try Oreilly's full synthetic yet?
$17.99
5 Qts. of O’Reilly Full
Synthetic Motor Oil &
a Mobil 1 Oil Filter
Includes Mobil 1 oil filters at $12.99 or less.
Limit 2 oil & filter specials per customer.
I'm going to throw some in the impala.....
Posted on: 2010/5/29 14:58
flyboy Re: Oreilly's full synthetic Oil change Special
That's a bargain.
Posted on: 2010/5/29 15:49
pianoguy Re: Oreilly's full synthetic Oil change Special
Wow, that is a great deal!
Posted on: 2010/5/29 16:14
Durango_Boy Re: Oreilly's full synthetic Oil change Special
Who manufactures their synthetic oils? The Mobile 1 filter is a good thing, and what weights do they offer, if more than one?
Posted on: 2010/5/29 17:04
Aboatguy Re: Oreilly's full synthetic Oil change Special
498 Posts
5w20 , 5w30 and 10w30... and they claim it meets or exceed GF4.... ...so theoretically it exceeds the specs needed for a LT1
manufactured by OMNI (Shreveport LA)http://www.oreillylubetech.com/
here's more info:
http://www.oreillylubetech.com/PDS/Synthetic%20Multigrade.pdf
Posted on: 2010/5/29 17:26
I just went and snagged a couple of those myself. $38 for 2 oil changes (including the governor's share)isn't bad at all.
Posted on: 2010/5/29 19:39
92LRC Re: Oreilly's full synthetic Oil change Special
Weston, FL
88 Posts
$17.99
where did you buy this?
Posted on: 2010/5/31 21:57
O'Reilly's auto parts chain.
Posted on: 2010/6/1 1:28
