232 user(s) are online (181 user(s) are browsing Forums)
Ultraman, more...
BrianCunningham Can you go downwind faster than the wind?
Posted on: 2010/7/6 4:00
CentralCoaster Re: Can you go downwind faster than the wind?
But you gotta time those overpasses just right...
Posted on: 2010/7/6 6:40
TommyT-Bone Re: Can you go downwind faster than the wind?
33766 Posts
One big drawback. It won't fit in the garage.
Posted on: 2010/7/6 11:43
How do you get it started? The prop is driven by headwind... but you don't have any headwind until vehicle speed exceeds wind speed.
Posted on: 2010/7/7 0:06
BillH Re: Can you go downwind faster than the wind?
There's a big rubberband inside of it.
Posted on: 2010/7/7 0:58
BrianCunningham Re: Can you go downwind faster than the wind?
downwind
the wind is directly behind you.
Posted on: 2010/7/7 0:59
With what, a huge sail? Or maybe they can pivot the blades like the do on the wind farms... use tail wind to drive the turbine up to a certain point, then pivot the blades to take advantage of the headwind. But then you have that dead spot where the car is travelling the same speed as the wind... what accelerates it then? Battery power generated from the turbine at park? That would be cheating.
Posted on: 2010/7/7 1:10
you didn't read the article did you?
Posted on: 2010/7/7 1:17
MK 82 Re: Can you go downwind faster than the wind?
Palm Beach Gardens, FL
439 Posts
Probably felt bad about doing it at work.
Posted on: 2010/7/7 3:21
96 CE Roadster LT4
I read it more carefully this time around but it does not address the issues I brought up. If it's propelled by the headwind (relative to vehicle speed) then it how does it get past 13 mph? And how does it store enough power below 13 mph to get past that threshold?
tailwind, not headwind
Posted on: 2010/7/7 19:23
That tailwind becomes a headwind when you go faster than it! Oh nevermind already...
Posted on: 2010/7/7 20:44
biggrizzly Re: Can you go downwind faster than the wind?
Tailwind never becomes headwind. It will always be blowing at 13mph from the rear. (sailors knowledge) What you feel in your face is called apparent wind and that is from you and the vehicle moving through the air. I guess this is where friction and drag is most important in these designs, the less drag the less friction from apparent wind. There are a few new sailboats out there that are breaking all kinds of wind speed records now using similar technologies. I find it interesting and need to do a little researchin' Also a sailboat moves through the water by utilizing airfoils more than using tailwinds. My boat will sail faster on a reach (wind coming from the either port or starboard side at about 45% to the direction of travel)than with a tailwind.
Posted on: 2010/7/7 23:00
Dammit Jim, I'm an engineer, not a sailor.
Posted on: 2010/7/7 23:06
Well after re-reading their article and digging a little deeper, they are not using any sailing theory as they say it gets too complicated, especially "wind coming from the side"(their words). They are just going on tailwind, momentum and I guess kinetic energy that gets stored when the prop turns. Its really fuzzy how they "gear" the prop and get the mechanical energy to the wheels. I'd like to see a real detail article about how they accomplished this.
Posted on: 2010/7/7 23:20
Here's a video explanation
Posted on: 2010/7/13 15:50
in words
-----Original Message-----
To: multihull_boatbuilder@yahoogroups.com
Sent: Mon, Jul 12, 2010 6:44 pm
Subject: [multihull_boatbuilder] Re: Answered: Can you go downwind faster than the wind?
Ok, we'll move forward on the assumption that a traditional modern sailing rig can propel a sailing craft to a speed such that it's downwind VMG is greater than the speed of the wind.
(The above assumption is easy to support in real life btw).
NOTE: below I have used some easy to work with numbers (like 45 degrees) simply for convenience. Actual numbers in real life may vary from these.
Imagine for a moment a world that rather than being shaped as a sphere is shaped as a cylinder. The cylinder 'world' is laying on it's side in our view and we are standing at the south "end" of the world on top of the cylinder. The entire surface of this world consists of one enormous uninterrupted dry lake bed with one wind blowing from the south to the north.
Let's send a land-yacht on a 45 degree reach running to the NW. Without making a single gybe, this craft will 'corkscrew' it's way around the world as many times as needed to reach the far end of the cylinder. We know that if we release a neutral bouyancy floating balloon into the wind at the same time as the land-yacht, by the time the land-yacht has made one circumnavigation of the cylinder world and reappears to us on top it will be significantly farther downwind and 'downcylinder' than the balloon. This of course is just a simple matter of the craft having a downwind VMG greater than 1.0 wind speed.
Now, imagine that when the initial craft we sent on it's 45 degree path is halfway around the world (and now on the 'bottom' of the cylinder), we set another identical craft off on an identical 45 degree downwind reaching path. We start this craft off at the same 'longitude' as our craft already in motion. What we now have are two land-yachts on opposite sides of the world, going the exact same speed and carving the same helical path -- all the while remaining exactly opposite of each other on the cylinder. Every rotation they make they cross the DDW path of the drifting balloon and each rotation they get farther and farther ahead of it.
Imagine now in this thought experiment that we begin to shrink our cylinder world a bit at a time. We have not changed the speed of the wind nor the speed of the land-yachts. As this 'world' shrinks, all that changes is the diameter of the helical path shrinks and the number of revolutions that the yacht makes in any given period of time increases. Keep shrinking this imaginary world until the wheels of the land-yachts are on such a small cylinder that they are essentially touching each other as they spin dizzyingly around and around -- their sails protruding in opposite directions.
If you are with me so far, you'll see that our two land-yachts are still achieving a downwind VMG of greater than 1.0 -- every time they rotate they increase their advantage over the floating balloon. Also, those sails spinning in a perfect circle are sure looking familiar (propeller anyone?)
Going a step further in this 'morphing' process, let's replace the chassis of both land-yachts with something more simple without making any changes to the spinning sails.
We know that both the sails and the chassis are carving a 45 degree helical path so let's dump the frames and wheels of the land-yachts and replace both of those with a single, oversized threaded rod. This rod is equipped with grooves that match the sails 45 degree path and is aligned with the wind, taking the place of the 'pole' of our cylindrical earth. Let's spin on a matching oversized nut and drop the masts into holes in that nut.
Now, without ever interrupting the spinning sails nor their downwind VMG >1.0 paths we have created the simplest DDWFTTW vehicle of all -- two spinning airfoils on a nut traversing a threaded rod. At the center of these rotating airfoils, we now have a nut that is going DDW and continuing to press it's advantage over the balloon with every rotation.
(Before taking the last step to our vehicle, it's interesting to note that the sole purpose of the keel mechanism on a traditional sailing rig is to force the airfoil to take an advantageous path through the air. In the case of a 45 degree reach, it's purpose is to ensure that for every foot that the airfoil moves downwind, it also moves one foot to the right (or left). It's this forced diagonal path through the air that creates the apparent wind needed to generate thrust. Of course the purpose of the non-articulated skates of an ice-boat, the wheels on a land-yacht and the threaded rod and nut in our above example serve the same purpose as the keel of the sailboat -- forcing the airfoil to maintain it's path diagonal to the wind.)
Last step: Once we reach the point that we have a pair of spinning airfoils happily pushing the nut DDWFTTW down a threaded rod, we need someway to translate this into a vehicle that can traverse any dry lake bed DDW. Realizing that to do this we only must find a way to force our airfoils to continue on their 45 degree helical path -- a path from which they have yet strayed, we arrange gearing between the wheel axle and the prop axle to ensure that for every foot the wheels roll across the dry lake bed DDW, the airfoil is forced through the air one foot to the side just as before -- and there you have it, DDWPDV -- a DDWFTTW vehicle.
As you can see, through this entire process the wind never changed directions, the angle of the apparent wind to the airfoils never changed, the speed of the airfoils through the air never changed, the downwind VMG of the airfoils never changed, the lift and drag vectors of any given airfoil section never changed -- in short, other than a slow change in the diameter of the helical path of the airfoil, all remained the same from "sail" to "prop".
Turns out that the airfoils of a traditional sailing rig on a faster than the wind reach and those of the DDWPDV are acting in the same manner -- one can *call* it sailing or not, but it's a distinction without out a difference from an aerodynamic standpoint.
Here is the 'Cliff-Notes' version of the above: The airfoils of the propeller are one loooong and continuous downwind helical reach while the chassis travels DDW. Adjusting the gear ratio between the wheels and the prop is the equivalent of adjusting your ground track on the land-yacht (and thus altering your sails path through the air) and changing the pitch of the propeller is the equivalent of adjusting the angle of the sail on the land-yacht.
Here is a link to an animation which illustrates the above:
http://www.youtube.com/watch?v=UGRFb8yNtBo
Hope this helps.
JB
Posted on: 2010/7/13 15:52
The earth is spherical?
Posted on: 2010/7/13 20:41
The rest makes sense except that I'm stuck on the first part:
"a traditional modern sailing rig can propel a sailing craft to a speed such that it's downwind VMG is greater than the speed of the wind."
What is VMG, and how does a sail travel downwind faster than the wind?
I understand how it travels faster than the wind, but not in the same direction.
Posted on: 2010/7/13 20:43
explains is better than I can
http://en.wikipedia.org/wiki/VMG
Posted on: 2010/7/13 21:16
Video
Posted on: 2010/7/13 21:17
Well that's impressive, never seen that before.
So the blade angle, while rotating still sees a tailwind, even though the vehicle overall is moving faster than the wind.
The rest is just energy. The amount of energy going into the sail becomes motion, there's nothing perpetual about it because energy is more than just velocity. Definitely counterintuitive... but really it's kinda like a bicycle in that sense, you can make a wheel rotate faster than your pedals.
So the next question is, how much faster can a sailboat go than the wind in theory?
Posted on: 2010/7/14 0:09
I'd have to look the record up
But iceboats have sailed well over twice the speed of the wind, over 100years ago.
Posted on: 2010/7/14 1:21
Ok, looks like there is no theoretical maximum which makes sense. I found some articles on iceboats travelling at 4-5x windspeed downwind. Ok, well they don't travel directly downwind, but very cool nonetheless.
Never heard of iceboats before, but it makes sense that they'd be more capable than a sailboat.
Ahh, the power of vectors.
Posted on: 2010/7/14 1:48
and very little resistance!
They were going over 60mph before cars were around.
Posted on: 2010/7/14 1:55
