383tpimachine | Switch panel? | ||
Do any of yall have a switch panel made?
I am looking to make a hidden panel to fit where the cupholders are in my 85 for 5 switches and a purge button. Fuel pump, water pump, Amp, Nitrous Arm, Interior lighting, and purge. Bottle will be in plain sight but I would like all the switches to be hidden as possible. |
Posted on: 2010/10/9 17:41
BillH | Re: Switch panel? | ||
I've made switch panels for all kinds of things, pretty easy to do. I haven't made one specifically for the cup holders but shouldn't be a problem.
Prototype it out of stiff paper/cardboard, transfer that to some sheet metal. |
Posted on: 2010/10/9 18:07
383tpimachine | Re: Switch panel? | ||
I have a cardboard template already made. Was just looking for pictures.
Im thinking about having Emblempros make it for me to have it done nearly perfect. I like the fact that they label. |
Posted on: 2010/10/9 18:16
CentralCoaster | Re: Switch panel? | ||
I have seen a few bitchin ones, I don't have links though. The cupholders are about useless anyways. I usually wedge drinks between the passenger seat and tunnel because the don't fit otherwise.
Posted on: 2010/10/9 18:17
bogus | Re: Switch panel? | ||
I have a vinyl cutter. If you want decals, let me know the point size and font, I can cut them for you. Pick a colour, too...
Posted on: 2010/10/9 19:02
badass bogus. I will let you know. Guess its time to start cutting some aluminum.
and I dont let anything but water bottles in my car so no worries there. |
Posted on: 2010/10/9 19:55
mseven | Re: Switch panel? | ||
Harris Speed Works makes some nice ones...mine:
[IMG]http://i53.tinypic.com/rlyvl3.jpg[/IMG] |
Posted on: 2010/10/10 0:04
Which one is that? Im guessing its the TBSS
Posted on: 2010/10/10 0:35
yes it is, I also use their micro edge +, and think they have a nice product line.
http://www.harrisspeedworks.com/home.php?cat=62 |
Posted on: 2010/10/10 2:06
I planned on using the micro edge+ or the FJO mini
Posted on: 2010/10/10 5:35
flyboy | Re: Switch panel? | ||
I like it.
Posted on: 2010/10/10 12:59
tuff96lt1 | Re: Switch panel? | ||
Do you happen to have any pics of the install ?
Wiring setup etc. |
Posted on: 2011/3/6 14:58
