219 user(s) are online (174 user(s) are browsing Forums)
jonszr1 well found out why she doesnt launch good
Lone Pine, CA
went to fontana yestreday anf ound out 2 things .1) if i put the tire pressure down below 19.5 the tires start moving on the rims . and 2 my clutch pack in the rear end is going out .one cant 60 ft with a one legged bandit . are there any better clutches i can put in the rear end or any little trcks anyone knows that will help ?
Posted on: 2010/12/5 18:49
bogus Re: well found out why she doesnt launch good
Well... short of putting some heavier fluid in the diff, I don't know what to suggest.
I don't like that idea, tho, might harm the bearings.
Gordon Killebrew recommends using two bottles of diff lube when changing the diff oil. This is more than the recommended one bottle.
Posted on: 2010/12/5 19:02
Steve40th Re: well found out why she doesnt launch good
1114 Posts
But why is Gordon recommending this? Quietness? Drag Racing?
Posted on: 2010/12/5 19:18
Ko'u ohana aia ku'a ikaika
I think it's because of what the diff additive does. It essentially adds friction modifiers to the oil. This must do something to the diff clutch, because he suggests it for durability.
Posted on: 2010/12/5 19:34
CentralCoaster Re: well found out why she doesnt launch good
How many runs did you get in and how long were you there?
Andy, you're talking about the posi additive right? I have to assume that adds some friction allowing the wet clutch to grip better.
Jon, have you checked the posi with a torque wrench? I recall that mine slipped around only 100 ft lbs, which seems awfully weak. I don't know what to compare it to. But I bet there are a ton of vette driving around with dead posis that don't even know it.
Posted on: 2010/12/6 3:46
jonszr1 Re: well found out why she doesnt launch good
Lone Pine, CA
i got in 5 runs in total and left around 2 pm . track was a little cold. best run of the day was 12.14@115.93 mph with a 1.903 60ft the other runs were in the 12.30s.a friend of mine darren made a video of 3 of the later runs on utube titled C4 ZR1 12/04/2010 fontana street legal drags .were you there i only saw 1 other c4 it was white had speialized plates and a girl driving it dont know what she ran . another friend was watching the car when i did burn outs and saw only 1 wheel was spinning hard the other was bearly spinning. has anyone looked into another type of locking rearend for the 44 rear end . i have an auburn detroit type locker in my 9 in ford rear in my 68 mustang . i wonder if they make something along those lines for our cars ????
Posted on: 2010/12/6 18:17
There is the spool option... and I think Eaton makes something for the D44 carrier.
Posted on: 2010/12/6 22:41
1114 Posts
What about this diff? I knwo teh Viper gears fit, but what of the carrier?
http://www.quaife.co.uk/catalogue/products/qdf9s
Posted on: 2010/12/6 22:54
Matatk Re: well found out why she doesnt launch good
GM friction modifier allows the clutches to slip more so there is no chatter in the rear end around corners, etc. Too much, though, and the clutches will slip too much and you lose the characteristics of a LSD.
Posted on: 2010/12/6 23:33
BrianCunningham Re: well found out why she doesnt launch good
Truetrac is an option
http://forums.corvetteforum.com/c4-te ... f-1-4-mile-users-yet.html
No, the Viper diffs aren't setup to use the halfshafts as upper links.
Besides that diff is $4k!
Posted on: 2010/12/7 0:20
Lone Pine, CA
brian did you own a zr1 ????
Posted on: 2010/12/7 0:55
No, but I called Quaiffe.
ZR1's run the same D44 I have.
That diff is one of the reasons Vipers did so well against the ZR1's back when they ran together in World Challenge.
Posted on: 2010/12/7 1:13
cuisinartvette Re: well found out why she doesnt launch good
Eaton makes a great posi unit
Only need 1 of those posi additive tubes, more is not better
IMO youll launch better with a heavier flywheel knowing the characteristic of a heavily ported LT5 opinions will vary
Posted on: 2010/12/7 3:11
Well in that case, I don't think more is better either. I'd want as little as possible needed to do the job.
Posted on: 2010/12/7 14:36
Lone Pine, CA
ron , with the heavier flywheel even leaving at 1500 rpms just caused the car to go up i smoke . i think i am going to go to the eaton diff i like the fact of not having clutches . i am going to bill boudreaus today and go with a steel 19lb flywheel that i got from callaway and a stage 3 ceramic disc clutch. he feels that the just a little heavier flywheel but not 46 lb stk will give me the best of both worlds . will see in jan .
Posted on: 2010/12/7 16:02
Think Carolina Clutch sells a billet steel 25 or 30 lber not a bad compromise. Personal taste I guess.
Posted on: 2010/12/8 3:59
