305 user(s) are online (247 user(s) are browsing Forums)
1st Gear: 1.76/1.82
2nd Gear: 1.00
- 14 Bolt Pan.
- Vac...
biggrizzly Flow numbers for the armchair racer in all of us
Ok - here are a few numbers for the number guys in all of us. I'm pretty happy with all of this and I plan to feed it into my little desktop dyno and see what it brings me.
These numbers for an LT1 stroked 383
Cylinder Head Flow Numbers
Factory LT1 heads with Manley 2.05 intake valves
1.xx exhaust
Intake/Exhaust
100 lift 62/61
200 lift 130/112
300 lift 178/160
400 lift 226/192
500 lift 259/208
550 lift 270/213
600 lift 271/217
Cam Specs
Duration 224/230
Lobe separation 113.0
Valve lift .566/.577 with 1.6 rockers
Posted on: 2011/3/25 19:51
PeteK Re: Flow numbers for the armchair racer in all of us
Looks like he spent time to pick the right cam.
It should compliment the compression ratio and cylinder head very well.
Posted on: 2011/3/25 21:39
biggrizzly Re: Flow numbers for the armchair racer in all of us
I think that Jerry Jackson is fairly conservative when he is building a street engine for a customer. I have seen guys here with a lot more lift and more overlap but I think this combination will be smooth running and easy for Mick to create a tune.
He did improve the flow characteristics of the heads from what I got from LE. Probably the difference between a LE2 and LE3 port job. I'll tell you.... I paid for that little bit of improvement!!! Flow at .550 lift went from a baseline of 258 to 270 and from 262 at .600 lift to 271
Of course this is all on paper. Also the bigger valves and the de-shrouding of the valves gave those improvements.
Posted on: 2011/3/25 23:05
Bigger is not always better.
On a street car, I think you have a damned good, well rounded combo.
Very similar numbers I would look for on my own builds.
My stuff often runs faster than the bigger combo's with the same cubes. Well matched is the key.
Posted on: 2011/3/25 23:27
pr0zac Re: Flow numbers for the armchair racer in all of us
i agree with pete. i think it will be a great street car. depending on if your stall is in line with how you drive it could make it even better.. but its all on what you want out of it.
Posted on: 2011/3/26 0:52
I'm using the same converter that Pete set up for me before. It's a 3,000 stall 9.5" converter. I think it should work pretty good with my 383 setup. The 3,000 stall converter worked great before. I didn't have any issues with the way the car drove under normal operating conditions. At the track it really stoked the launch but when driving to the grocery store it behaved quite docile.
Posted on: 2011/3/26 1:13
Matatk Re: Flow numbers for the armchair racer in all of us
Sounds like 600 hp to me
Posted on: 2011/3/26 1:52
Oh No! Is that you JSUP!
Posted on: 2011/3/26 2:55
Stl94LT1 Re: Flow numbers for the armchair racer in all of us
128 Posts
Wow, that's the largest valves I've seen in a stock LT1 casting.
Posted on: 2011/3/26 14:07
LE3 lt1 heads use 2.055 valves.
Posted on: 2011/3/26 16:30
Yes... 2.05 intake, but I did screw up on the exhaust valve and I can't remember what Jerry said he put in there. Might be 1.58 or something like that... I know its not 1.95" like I had originally said above.
Posted on: 2011/3/26 17:23
1.56?
Posted on: 2011/3/26 17:31
pr0zac wrote:
1.56?
1.56 sounds right, but Jerry didn't put the exhaust valve diam. on the flow sheet, just the intake valves. Which I knew because he called me and told me that he ordered the 2.05 valves since they were the same price as the 2.00 valves.
This whole thing got started when we found excessive wear to the installed valve guides and one of the 2.0" original valves had cracked. Also, Jerry was pissing and moaning about the crappy port job on the heads. So, I broke down and told him to go ahead and re-do the heads. I was just going to have him replace the guides and the one bad valve but again he didn't care for the Ferrea valves that were installed. So I told him to go ahead and put all new Manley valves instead. He did a baseline flow before and after which showed some good gains in flow over the previous LE2 port work. Plus he had to do some more un-shrouding of the valves to accommodate the larger intake holes. He even went so far as to chamfer the cylinders to allow the gasses to smoothly pass over the ridge created by the cylinder edge at the combustion chamber top.
Posted on: 2011/3/26 17:53
128 Posts
OK, the 1.95 exhaust valve was throwing me off.
Posted on: 2011/3/26 18:32
