mistaben | quick tunerpro question - how do you know when your in closed loop? | ||
thanks! |
Posted on: 2011/9/5 18:08
Matatk | Re: quick tunerpro question - how do you know when your in closed loop? | ||
I haven't looked at Tunerpro in a while...I know on datamaster there is a box that flashes I think red/green with text for open/closed. Have you checked in all the menus?
Matthew |
Posted on: 2011/9/6 2:03
mistaben | Re: quick tunerpro question - how do you know when your in closed loop? | ||
yea... i just started letting it idle for aobut 2 mins. I don't think you can update blm's if you are in open loop?
thanks though btw. |
Posted on: 2011/9/6 2:37
I don't think you will be able to adjust blms in open loop either.
Are you running a heated o2 sensor? I had a problem with mine dropping in/out closed loop. Matthew |
Posted on: 2011/9/6 2:47
how did you know it was dropping in and out of closed loop? datamaster?
I am not using a heated o2 sensor unfortuanately lol, but it is a pretty warm car already... and it is arizona... lol. ... I can try a run with datamaster tomorrow and find out for sure. good idea btw, thanks. |
Posted on: 2011/9/6 4:04
vetteoz | Re: quick tunerpro question - how do you know when your in closed loop? | ||
Datamaster has a box at top RH that says Open Loop in yellow in OL ;shows Clsd Loop in green when in CL When O2 is working correctly ,O2 voltage should rapidly change from say 300 -700 and back again Quote:
Stock the CL timer is set at 3 minutes for a cold start. |
Posted on: 2011/9/6 6:52
joshwilson3 | Re: quick tunerpro question - how do you know when your in closed loop? | ||
How do you know if you're running rich or lean in open loop? |
Posted on: 2011/9/21 5:45
Woodstock | Re: quick tunerpro question - how do you know when your in closed loop? | ||
How do you know if you're running rich or lean in open loop? Common senses, spark plugs, exhaust gases or wideband O2. New TP Version 5 has the "closed loop" checkbox on the bottom of "Show Data List Views". The old Version 4.x, which I still prefer, has it under "F" values. |
Posted on: 2011/9/21 8:08
91 convertible |
flyboy | Re: quick tunerpro question - how do you know when your in closed loop? | ||
Posted on: 2011/9/21 12:52
That doesn't tell you if it is running rich or lean in open loop. But I guess just get the BLM's right in closed loop, then it should hopefully be running correct in open loop. |
Posted on: 2011/9/22 2:11
I don't have a wideband 02, I keep everything stock. Don't have anything to check exhaust gases with. Don't see how you can look at spark plugs to check if its running lean or rich in open loop. |
Posted on: 2011/9/22 2:15
sure you could. start and stop the engine running it for about 2 minutes total a couple of times...
pull the plugs and check 'em. |
Posted on: 2011/9/22 5:25
89Vette | Re: quick tunerpro question - how do you know when your in closed loop? | ||
In case you still need to know... Below the large variable window (where ALDL Dash items are normally being monitered), you'll see 5 tabs. ALDL Values ALDL Dash ALDL Flags ALDL Monitors Item Comments About the 3rd item down on the ALDL Flags tab is the Open Loop status. It'll say OPEN or CLOSED. |
Posted on: 2011/9/22 14:19
383 stroker -- Semi-Siamesed SLP long-runner intake, AFR 195's, 4-2-1 headers, and a SR cam. ZF6 short-throw shifter. Custom body/interior. |
oh! - no i never knew that! thankyou! |
Posted on: 2011/9/26 22:35
