295 user(s) are online (249 user(s) are browsing Forums)
The Natio...
crazytigr96vet383 Dana 36 question
Covington , ga
8 Posts
so i just found out i got the 259 gear,in my 96 automatic. my next question is will the dana 36 hold up if i change the gears to 373? I believe my car will dyno out at around 400 rwhp once im done.im at 365 now with a stock revlimeter and stall convertor.
Posted on: 2012/6/16 19:27
Edited by Matatk on 2012/6/17 2:57:37
crazytigr96c4/383
Matatk Re: Dana 36 question
The Dana will accept the 3.73 if you get the right ring and pinion kit. The D36 will handle the power but it will be spinning...especially with 3.73s or 3.54s. Once you put sticky tires (ie, DRs or slicks) it will blow up. You'll need a D44 swap for big power and sticky tires.
Posted on: 2012/6/17 2:59
bogus Re: Dana 36 question
It will... but not for very long. A couple of hard launches and I think you will be seeing oil.
The D36 is fragile, and, to be honest, I think the 3.73 gear is a bit much for the 4L60E.
I would consider a D44 with 3.42 gears. Those are the stock 6spd gear, and with your OD ratio, would still cruise ok... lemme think here... 5th gear is .76, 6th gear is .51... at 75mph, my 92 is turning about 1800 RPM in 6th, and 2500 in 5th.
Now, your OD is .64, IIRC, which splits the difference between my 5th and 6th gears. In short, I would think that a 4L60E with 3.42 gears would spin at about 2200 RPM at 75mph.
Not bad... not great, but not bad.
Posted on: 2012/6/17 3:01
biggrizzly Re: Dana 36 question
I have the old Dana 36 in mine. When I put the 383 in the car I had PeteK build the transmission for me and had one of the guys I know at Sport Chevrolet rebuild the dif with new Richmond 3.56 gears.
I estimate that I have about the same power you are suggesting and the only problem I have at this time is traction. I have some three year old 315 Sumitomos on the rear and they just spin like crazy with moderate pressure of the gas peddle.
Like Andy said - with sticky tires and hard launches it might not hold up so well.
Bottom line... If you're an old puss like me, then the D36 will probably be OK for you. If you are young and pushed to destroy, then I would upgrade to the D44.
Posted on: 2012/6/17 11:16
mfi Re: Dana 36 question
Long Island
5 Posts
I've done a ton of research about this, just got a 3.07 rear to replace my 2.59..my motor is stock so I'm not worried about it. If you go with anything higher than 3.07 you will have to replace the speedometer gear at the tail end of the tranny and the one in the VSS.no big deal but its harder to get the speedometer right. You will also be buzzing pretty high at highway speeds, I've read 3.73 is pretty much the limit with these autos...changing to a Dana 44 is a big job, way more involved but will handle anything..all depends on what kind of driving you do..for stoplight wars the 3.73 will be great but will not last too long..
Posted on: 2012/7/3 17:19
MFI - calculating the correct gears to use actually is pretty easy. If I recall, Kevin has the chart listed on his website.
I honestly don't think a D44 swap is much more difficult than a D36 swap. You have to change (or redrill) the c-beam and use a shorter driveshaft as well as the D44 batwing. That's about it. If you're pulling the D36 out for a gear swap or pumpkin swap you've got 90% of the work done already.
3.07 is pretty much ideal for a tpi motor, the lt1s with the higher revs can benefit more from a gear like 3.73.
Posted on: 2012/7/4 1:57
RickAnthony Re: Dana 36 question
ASE Master Certified
Downers Grove, IL
703 Posts
I did the 3.75 gear set in mine from richmond.. waste of money on a dana 36. The 3.54 gears is what I would go with if your keeping the dana 36. I think they will hold up fine if installed and properly broken in,and of course not running slicks all the time...
I'm content for now with my 3.07 diff (mine too had the 2.59 first thing I really didn't like about my car when I bought it, couldn't even spin the tires from a stop with it)
Keep in mind, the larger the ring gear the smaller the pinion. I think the larger gear sizes (over the 3.07) fail often becuase the pinion cannot handle the load on it. I've seen this a few times, it's how my 3.73 set failed, and just recently a 3.54 set on a diff that was a rebuilt unit the customer had purchased from one of the catalogue companies, where he lost a good portion of one of the teeth. It was still driving though loud like this, he probably got 50K miles or so out of that diff though..
FYI 94-96 with flash programable PCM does not need the speedo gears changed ect. You can flash with with either a hand held programmer or tuning software via laptop such as tuner cat, lt1 edit ect...
-=Rick
Posted on: 2012/7/4 2:00
My Automotive Blog
CORVETTE SERVICE & REPAIR
RickAnthonyMotorsports.NET
RickAnthony wrote:
[quote]
-=Rick
Good advice and thanks for pointing out the PCM flash issue, Rick, I forgot about that
Posted on: 2012/7/4 2:51
Downers Grove, IL
703 Posts
That's ok Matt, I work on these all the time and I forget things as well as learn things new all the time...
Posted on: 2012/7/4 4:28
My Automotive Blog
vetteoz Re: Dana 36 question
mfi wrote:
I've done a ton of research about this,.
http://webpages.charter.net/khasting/images/parts/93.gif
Possibly one of the easiest diff swaps going ; < 1/2 a day for one man with a floor jack and some axle stands
At least a hour faster and a lot cleaner than just doing a diffhead swap in a D36
Posted on: 2012/7/4 8:28
