matts85vet | broken valve spring -- need advice | ||
the ex valve spring on #4 broke. the valve didn't drop down completely, only about 1/4 inch. retainer and keepers still on the valve.
leak down test shows same results as other pistons-all around 5%. i pulled the head today. no damage as far as i can tell without some more cleaning. the valve did touch the cylinder and wore away some of the buildup of grime, and you can see where there was contact. i still need to remove the broken spring and valve and clean it up. the pistons are forged? its an 85. it was a comp beehive i ordered a new nitrided series set #1519 from pac, yet to arrive what should i do? ill try to get pics tomorrow thanks in advance |
Posted on: 2012/9/23 3:45
85 coupe, 383, TPIS Miniram, auto 700R4, 3.75 gears, afr 180 eliminator heads 58cc, 12:1 compression ratio, comp cams 280XFI hydraulic roller cam, 1.65 roller rockers, 52mm throttle body, c5 calipers, hedman elite longtube headers, pypes dual exhaust w/x- |
bogus | Re: broken valve spring -- need advice | ||
It seems you already have the answer... I would replace springs and move on.
I assume the miles on the engine are rather low, right? |
Posted on: 2012/9/23 3:50
Matatk | Re: broken valve spring -- need advice | ||
My question is why did it break? What RPM are you running at and are the springs you selected suited for your cam?
Posted on: 2012/9/23 11:49
rklessdriver | Re: broken valve spring -- need advice | ||
Since you can see where the valve contacted the piston, I would recommend you take that valve to a machine shop and have it trued up.
It takes alot more than a valve bump to damage a piston. Nothing to worry about there. Will |
Posted on: 2012/9/23 22:20
EngineDoctor | Re: broken valve spring -- need advice | ||
Yes , have a machine shop set u you up !
Posted on: 2012/9/24 1:05
