sprint7677 | XM installation | ||
Any good tips on installations?
Posted on: 2008/1/13 4:51
biggrizzly | RE:XM installation | ||
I installed a Sirius receiver in mine last year. I was going to mount the antenna under the rear deck fiberglass but decided to keep it on top the halo. I ran the wires under the carpet and then under the side kick plate area, and then up behind the A-pillar cover where the receiver is mounted with the suction cup mount low and close to the dash. It is out of the way but visible and easily accessed.
I also used a Sirius adapter that hard wires the unit into my Bose radio antenna. similar to an RF converter but no radio waves to worry about and it sounds awesome. I'm not sure if XM has the same thing but they probably do. Is your unit part of a head unit or is it a separate receiver like mine? Good Luck - You will love having satellite radio in your Vette. |
Posted on: 2008/1/13 5:34
bogus | RE:XM installation | ||
my antenna is stuck to the painted part of the hatch glass.
are you going with a dedicated receiver module or with a portable unit? I have found that the dedicated receivers sound better. |
Posted on: 2008/1/13 7:17
sprint7677 | RE:XM installation | ||
This is the one I'm getting
The Delphi Roady XT is the smallest and lightest XM Satellite Radio available. Coming with everything you need to enjoy XM satellite radio in your vehicle, the Roady XT and XM Satellite Radio service are all you need to access digital-quality continuous programming across the United States. And with the Roady XT offering a true plug & play design with simple docking and connection, you can also receive XM's great programming in your home, office, at the beach, or on the go. Features: Vehicle Ready - Comes with everything you need for use in the vehicle Easy Installation - Plug & Play solution for installation in any vehicle or at home with the purchase of the Roady XT Home Kit Cutting-Edge Design - Sleek, innovative, compact design that delivers high sound quality Built-in Wireless FM Transmitter - With all frequencies available makes any FM radio an XM radio Tune Select - Helps you find your favorite artists and songs on any XM channel Info Extras - Keeps track of your favorite sports scores and stocks Custom Back-Lit Display Colors - Seven new custom colors and convenient backlighting on all control buttons SureConnect Kit Includes: Roady XT Receiver Car Cradle Magnetic Mount Car Antenna Car Power Adapter Swivel Mount Vent Mount Cassette Tape Adapter SureConnect Kit User Manual Specifications: Dimensions without cradle: 3.7" W x 2.25" H x 0.7" D Weight without cradle: 0.16 lbs. (76 g) Audio output: variable through 3.5mm jack Antenna (Home/Car Cradle): SMB External power: 5V DC Featuring the all new XM SureConnect. SureConnect is XM's answer for your FM modulators, providing the most superior reception and sound quality during FM transmission in the car or elsewhere. You can find visual instructions here. |
Posted on: 2008/1/13 12:27
red_johnny | RE:XM installation | ||
I just installed one of those in my buddys car. Really easy, your bigest concern here is how to run the wires. Other than that just follow the directions
Posted on: 2008/1/13 14:12
Wires should not be too hard, just wondering about a clean and accessable way to mount it
Posted on: 2008/1/13 19:01
no clue... I don't have any experience installing these...
I guess it's gonna have to hang somewhere... If it was me, I would sit it in the console... versus drilling into the sides of the console. Then again, you can't see the display. This is why I went with the integrated solution with Sirius. |
Posted on: 2008/1/13 19:09
Hmmm, never thought of where to mount one in the vette. There are a few ways to go about it. You could mount it on the top of the dash or to the right of the radio but that would require a special mounting kit.
Posted on: 2008/1/13 23:53
Jeffvette | RE:XM installation | ||
In all honesty, if you are going for a Sirius unit, get one of the sportser models. The best feature they have is the buffer so you can pause and rewind.
I will second the notion of getting a dedicated headunit, as FM reception sucks. They sounds is lower compared to a regular radio station and static interference pops up to often. Also, do give a try with mounting the antennae inside the bumper and see how you do reception wise. Makes for a much cleaner install. |
Posted on: 2008/1/14 0:32
In all honesty, if you are going for a Sirius unit, get one of the sportser models. The best feature they have is the buffer so you can pause and rewind. I totally disagree with you here. The reception is very good and I hear no difference then a wired connection. And to buy a more expensive unit just to be able to pause and rewind is nutz. But its all in what you are going for. You in the end have to make the decision. |
Posted on: 2008/1/14 1:19
As I stated in my earlier post = Sirius has a special adapter that hard-wires the reciever into the antenna lead of the car's reciever. This makes for a perfect reception. I'm sure XM must have something similiar.
I routed all my wires up the A-pillar under the moulding. When the three wires exited the moulding I used some spiral covering to consolidate the wires. I also made this as short as possible to make it less noticble. The unit is mounted to the inside glass using the supplied windshield mount and in the location I have choosen, looks good if you don't go the integrated route. My Toyota Matrix has a high dollar DVD/Nav/Satelite system in it with an integrated Sirius radio. It does NOT get as good reception as my Corvette and has dropouts more often than I like. |
Posted on: 2008/1/14 14:52
Where did you mount the satellite antenna?
Posted on: 2008/1/14 15:23
PIC?
Posted on: 2008/1/14 15:24
FLYINLOW90 | RE:XM installation | ||
I know the pic is big but rather than resize it I left it to make it easier to see the antenna mounted in the Vette. Gary |
Posted on: 2008/2/8 21:55
I got fun..Ya want Some? :tongue: |
Hmmmmmm, and it works fine with no fade being mounted inside?
Posted on: 2008/2/8 23:01
1984 Corvette mostly stock, many new parts |
Hmmmmmm, and it works fine with no fade being mounted inside? Nope.. Reception is great. I have 4 XM's. 1 is in the big truck with an exterior mirror mount for big trucks but the other 3 are in my cars. All the cars have the antenna mounted on the dash as in the pic with no reception problems. Just use a small piece of velcro and your good to go. Gary |
Posted on: 2008/2/9 1:28
