240 user(s) are online (167 user(s) are browsing Forums)
PLRX DIY Window Guides
SoCal
212 Posts
First I would like to say thank you to Robert Ibarra(VetteUSA). Five years ago he started a thread
with a DIY instructions on how ti replace our infamous window guides.
[url]http://forums.corvetteforum.com/c4-tech-performance/1721996-the-official-c4-corvette-window-alignment-write-up-pdf.html[/url]
Back in 2006 I was driving from Graceland to the NCM, and suddenly both windows made a weird noise.
I think it was the high winds in Kentucky that broke the window guides. The windows always worked, and
I got used to work around it. In 2007 Robert started his thread, posted a PDF file, and I was lucky enough
to save it.
Last year road trip made the windows worse, and finally I bought the guides. Finally today the new guides
are now installed.
I started with the drivers door. removed the panel and all the BS that comes with it.
You can see it is broken in half allowing the window to dance all over the space.
I removed the whole aluminum panel, it made it easier and faster to complete the task. This is the door handle
snap, and it was very friendly.
Special tool
The good and the bad.
Replaced all nylon fasteners. The old ones were like the rest of the C4 plastic; cracked and unserviceable.
Window no longer hits the pillar.
Passenger side.
This one was totally destroyed.
I had to use Robert's trick on the passenger side.
The PDF is no longer available on-line, but I will attach it to this thread for you guys to save it. Trust me, this is gold.
Posted on: 2012/10/26 3:45
bogus Re: DIY Window Guides
impressive!
I wonder what mine look like???
Posted on: 2012/10/26 5:19
Matatk Re: DIY Window Guides
Thanks for the write up! I'm sure we will all have to do this eventually.
Posted on: 2012/10/26 11:59
pianoguy Re: DIY Window Guides
Excellent write-up - thanks a bunch!
Posted on: 2012/10/26 12:20
-=Jeff=- Re: DIY Window Guides
Bartlett, IL
573 Posts
Can you get the guide rod from somewhere?
the earlier cars don't have the guide and have to think it might help with aligning the window.
Posted on: 2012/11/7 5:25
-=Jeff=-
1990 Corvette ZR-1 #1051
84Xfire Re: DIY Window Guides
Lake Havasu City, AZ
44 Posts
I can't find the attachment....this will be useful on my passengers side window.
Thanks!
Posted on: 2012/11/11 13:51
PLRX Re: DIY Window Guides
SoCal
212 Posts
The PDF file for Scott
pdf C4 Corvette Window Guides.pdf Size: 295.85 KB; Hits: 909
Posted on: 2013/3/14 6:59
