corvetteronw | Am I on the right track with this no start? | ||
91 L98. This week I have been unable to get her to fire up. Pulled codes (none), checked spark (it's strong), checked timing while it cranked (right on).
Checked fuel pressure while cranking: goes from 0 to 68 lbs after 20 seconds of cranking. My book says it should be at 40-42 lbs while cranking. I checked #1 plug and it is wet and checked the oil dipstick (no fuel smell and not too high on dipstick). There is a gasoline smell after I crank on it for a while but I see no external leaks. Engine will not even cough. I think I have a bad fuel pressure regulator. It came with my replacement intake manifold so I have no idea how many miles are on it. When I replaced the O rings in the fuel rail recently the existing rings were intact but some of them were a bit mushy. I can get a fuel pressure regulator rebuild kit from Corvette Central for mid $80 range. I will check with the local NAPA store to see if they make one too. Does it look like I am on the right track or should I be looking elsewhere? Go Detroit Tigers! Getting ready to watch game 6 and hoping for the best. |
Posted on: 2013/10/20 0:05
A VETERAN IS SOMEONE WHO AT ONE POINT WROTE A BLANK CHECK MADE PAYABLE TO THE UNITED STATES OF AMERICA FOR AN AMOUNT OF UP TO AND INCLUDING THEIR LIFE. |
bogus | Re: Am I on the right track with this no start? | ||
gee... sounds like too much fuel pressure is blowing out the spark... in short, it's flooding.
TPiS also has a nice AFPR. |
Posted on: 2013/10/20 0:07
corvetteronw | Re: Am I on the right track with this no start? | ||
The AFPR is the "hat" and disc only. I need the rubber guts too as mine are rotted.
Posted on: 2013/10/20 14:21
Matatk | Re: Am I on the right track with this no start? | ||
Order the diaphragm from tpis, they have the best price. Sounds like that is your problem.
Posted on: 2013/10/20 16:54
Schrade | Re: Am I on the right track with this no start? | ||
What's your static pressure? (before cranking) And pressure leakdown time?
Posted on: 2013/10/27 14:57
CentralCoaster | Re: Am I on the right track with this no start? | ||
You sure your fuel pressure guage is good? Is this a diagnostic gage or something you leave on the rail?
Posted on: 2013/10/27 22:37
Frank | Re: Am I on the right track with this no start? | ||
Fuel pressure is a bit too high but I'm thinking along the lines of either a bad Crankshaft or Camshaft Position Sensor. It will show a spark but a weak one.
Posted on: 2013/11/21 22:50
The old school L98 lacks both sensors...
Posted on: 2013/11/21 23:03
