238 user(s) are online (135 user(s) are browsing Forums)
matts85vet engine break-in oil and filter
Toledo, Ohio
58 Posts
what do you guys usually use? how long before you change it?
thanks!
Posted on: 2014/1/18 2:47
bogus Re: engine break-in oil and filter
filter? K&N.
Oil? I use basic Castrol GTX, but you may want to check out the high-zinc content racing oils.
Also, I change mine out about 100 miles in and again at 1000, then it should be ok.
I would change to synthetic at about 4k to 5k miles.
Posted on: 2014/1/18 4:20
Matatk Re: engine break-in oil and filter
Flat tappet cam? If so, buy the special, expensive break in oil that contains zinc for flat tappet cams. Do not use synthetic for break in.
I changed my break in oil at 20 minutes, then 500 miles, then 1500 miles, then 3000 miles. Overkill, but cheap insurance.
Posted on: 2014/1/18 12:32
matts85vet Re: engine break-in oil and filter
Toledo, Ohio
58 Posts
thanks for the replies!
it's a retrofit roller cam. the guy at oreily's suggested mobil 1 synthetic plus lucas additive.
do you reuse the same oil filter after you change the oil at 20 min. or 100/500 miles? or is it a new filter each time?
Posted on: 2014/1/18 14:26
85 coupe, 383, TPIS Miniram, auto 700R4, 3.75 gears, afr 180 eliminator heads 58cc, 12:1 compression ratio, comp cams 280XFI hydraulic roller cam, 1.65 roller rockers, 52mm throttle body, c5 calipers, hedman elite longtube headers, pypes dual exhaust w/x-
BillH Re: engine break-in oil and filter
We don't even do that with race engines, and the pro builders don't.
Warm it up, run it to readline in a couple gears, the rings will be seated.
Run it a few miles and change to synth, done.
Posted on: 2014/1/18 14:38
Well Bill, you are welcome to do that but I don't have the luxury of rebuilding my motor every season.
Posted on: 2014/1/18 17:01
I don't do it on street motors either Matt.
And I got 100,000+ on the last one.
Posted on: 2014/1/18 18:29
BrianCunningham Re: engine break-in oil and filter
Builder said he would have broke it in on the dyno, but I needed to get 200 miles on the clutch 1st in order to break it in.
Posted on: 2014/1/18 19:52
Danspeed1 Re: engine break-in oil and filter
Mooresville, North Carolina
1121 Posts
Posted on: 2014/2/5 17:46
1972 Chevelle SS 454
1995 Corvette Convertible
1996 Ford Explorer
2009 Cadillac CTS-v
