| j3studio | Thoughts On Recovering A Small Rubber Part? | ||
The 90 degree rubber connector for the CCV in my emissions system is A) loose and B) somewhat heat damaged. Finding a replacement has so far proven to be impossible - I can't even find a part number for it. Does anyone have any thoughts on anything that could be done to recover this connector at least a little bit? |
Posted on: 2014/4/25 12:30
Transfer
| hcbph | Re: Thoughts On Recovering A Small Rubber Part? | ||
I don't know if it's the same part or not, but I had a 90 degree fitting that went from the tube off the pcv valve into the intake that had been replaced with a piece of heater hose on mine when I bought it. Mine was heat damaged and collapsed also.
The hose was 1/2" heater hose so I went to NAPA for a replacement - no luck. They did let me look around in back at the various preformed hoses to see if I could see something that would work and I did find one. I found a preformed hose with a 90 degree bend in it. I cut it down to the length I needed from the bend and it went on perfect. I may still have the end with the NAPA number on it, if that sounds like what you're looking for, PM or email me and I'll see if I can dig it up. May take me a couple of days to get to it though. Hope that helps. |
Posted on: 2014/4/25 12:55
Transfer
| BillH | Re: Thoughts On Recovering A Small Rubber Part? | ||
If you can't find an elbow.
Plasti-Dip might work, it's the stuff you dip a tool in to put a rubber coating on the handles. Also known as Rubber Dip. Corvette restorers sometimes use it to make the rubber coated J clips that hold the wire harness on the firewall. |
Posted on: 2014/4/25 13:44
Transfer
| bogus | Re: Thoughts On Recovering A Small Rubber Part? | ||
GM Part numbers... ask and ye shall receive...
![]() Grommet - 3989349 Hose (looks like 90*) - 14082442 Try xrefing those numbers at RockAuto or call up Chris May at Superior Chevy... |
Posted on: 2014/4/25 14:02
Transfer
| j3studio | Re: Thoughts On Recovering A Small Rubber Part? | ||
Quote: bogus wrote: Andy, The part in question is much shorter, but you've given me some good ideas. Thank you. |
Posted on: 2014/4/25 15:23
Transfer
| joeld | Re: Thoughts On Recovering A Small Rubber Part? | ||
I "think" I used this one awhile back on a SBC engine, Not 100% sure.
Joel http://www.summitracing.com/parts/rnb ... Pa92pL8-70CFdEF7Aodgl0AlA |
Posted on: 2014/4/25 15:41
1989 Coupe,L98 automatic |
Transfer
Where on the engine is this part? |
Posted on: 2014/4/25 16:23
Transfer
Quote: bogus wrote: Three pictures: one of them of the general area, a close-up, and the actual part. |
Posted on: 2014/4/25 20:40
Transfer
I will check tonight.
Posted on: 2014/4/25 21:16
Transfer
Quote: bogus wrote: I know other things happenned ... ... can you take a look? |
Posted on: 2014/5/1 2:56
Transfer
yes I will! Hadn't forgotten... you are quite right, many things have happened...
Posted on: 2014/5/1 17:33
Transfer
these should be the numbers you need:
14082445 14087567 14082446 |
Posted on: 2014/5/2 5:01
Transfer
Quote: bogus wrote: Thank you, Andy - ordered. By the way, two out of three of these parts don't even show up in the 1985 Y-body parts manual ...
Posted on: 2014/5/10 20:11
Transfer
ah... You see... I have the entire Corvette parts fiche in PDF format... Trust me, I don't memorize all of this crap!
Posted on: 2014/5/10 21:39
Transfer
A final update here. The rubber part that I needed and that Andy tracked down turned out not to exist anywhere. I ended getting up an HPS high temperature silicone hose (designed for turbo applications) with a ninety degree bend and cutting it to fit. It's tight in there and I'll need to color the ends black, but it seems to be working. |
Posted on: 2015/7/4 20:12
Transfer
I am not surprised you couldn't find the parts...
I am finding more and more generic parts through the HELP! line at the various autoparts stores... |
Posted on: 2015/7/5 21:44
Transfer
| BrianCunningham | Re: Thoughts On Recovering A Small Rubber Part? | ||
Pep Boys has a really great selection of that stuff.
Used it for reliability test rigs |
Posted on: 2015/7/5 23:20
Transfer
| CentralCoaster | Re: Thoughts On Recovering A Small Rubber Part? | ||
Damn, I got all excited and crawled into my parts bin, but then realized I have the wrong elbow, to the valve cover part.
1st world problems! It's like that damn mcdonalds monopoly game all over again. Dorman (Help!) has a decent selection of doodads, some of which are the same fit as factory parts, but you'd never find them listed properly for the application. Here's a start, may at least be something that looks closer to stock. I assume you already checked the catalogs for aftermarket replacments. https://www.google.com/search?q=pcv+el ... IlfehpbnIxgIVzpSICh1V9AD2 |
Posted on: 2015/7/7 7:03
Transfer
| CorvetteBob | Re: Thoughts On Recovering A Small Rubber Part? | ||
Now wait just one minute..... Isn't the GRAND Imperial Poobah s'posed to have it memorized? I thought the "GRAND" was for the superhuman capacity you possess. Does this mean you're actually a "Normal" Imperial Poobah? This is just too much for me to take in.... |
Posted on: 2015/7/9 0:25
Transfer
Transfer
