wilsonbh | Change out Plug Wires on Drivers Side for a 1994 LT1 | ||
Has anyone changed out the plug wires on the driver's side without removing any parts? Can it be done?
Billy |
Posted on: 2008/1/24 10:35
1994 LT1 Coupe, Automatic, Hypertech Tuned/160 mod, K&N Filter Meziere HD Electric WP, MSD Optispark, Copper Metallic |
CasetheCorvetteman | RE:Change out Plug Wires on Drivers Side for a 1994 LT1 | ||
Yes, if you reach up from the bottom or reach under the power steering pump you can get to them no worries.
Posted on: 2008/1/24 12:29
biggrizzly | RE:Change out Plug Wires on Drivers Side for a 1994 LT1 | ||
Easiest done with two people; one up top and one below to guide the wires. It's tight and can be a PITA but its not bad when two people do it.
Good Luck |
Posted on: 2008/1/24 13:08
Notorious | RE:Change out Plug Wires on Drivers Side for a 1994 LT1 | ||
If I remember right from doing this long ago when my engine was stock, unbolting the steering pump from the bracket should make this a ton easier. (No need to unhook any hoses) My factory manual stated that the pulley must be removed to unbolt the pump. That is wrong, it does not. The bolts are a little tricky to find but not difficult to remove once you do so.
If anyone ever has the accessory bracket off, there's a place where some material can be ground away that will make future plug wire changes much easier. And when you see the obvious area I'm speaking of, you'll see it will have no effect on the structural integrity of the bracket. |
Posted on: 2008/1/24 16:34
I hate sporks... |
BillH | RE:Change out Plug Wires on Drivers Side for a 1994 LT1 | ||
If you remove just the pulley, you don't to loosen up the p/s unit. Since you have to pull the belts anyway, removing the pulley only takes 2 minutes. It makes it easy to see and get to that side of the opti. For $24, it's a pretty good investment.
Posted on: 2008/1/24 17:27
fnsblum | RE:Change out Plug Wires on Drivers Side for a 1994 LT1 | ||
I am sixty + and not near as handy as I used to be. I was able to do mine without too much difficulty by removing the belt, tensioner assembly and part of the wheel well. Good luck. Later! Frank
Posted on: 2008/1/26 23:43
93 Red LT-1 Bought in Nov. First mod is a set of Magnaflows. |
I got to them without taking anything off mine, but it was quite a tight squeeze
Posted on: 2008/1/27 3:18
