197 user(s) are online (176 user(s) are browsing Forums)
Also known as SMC.
The only issu...
TommyT-Bone 90 C4 Reasons for not getting a mph reading
MPH reads 0 at any speed. The 90 is obviously rebelling for not using it on a regular basis. Possible issues that may cause this? Another issue is it stalls out on deceleration. I put in some fresh fuel and have to run it a bit to see if it continues. It idles on start/restart and accelerates fine. Any thoughts are welcome.
Posted on: 2014/11/8 18:52
TommyT-Bone Re: 90 C4 Reasons for not getting a mph reading
Speedo sensor on left side of the transmission is one possibility and one I'm leaning to. Worth a look.
Posted on: 2014/11/8 19:55
pianoguy Re: 90 C4 Reasons for not getting a mph reading
Speedo mojo! There is nothing worse than a bad speedo:
Posted on: 2014/11/8 23:16
Matatk Re: 90 C4 Reasons for not getting a mph reading
My first guess would be vehicle speed sensor that you mentioned. The car will throw a code for a bad VSS.
Stalling on decel could be the IAC or several other things.
I would check for codes first.
Posted on: 2014/11/9 12:22
bogus Re: 90 C4 Reasons for not getting a mph reading
I agree.
The VSS is my first guess, and it might be why it's stalling. The controller does not know vehicle speed... things get complicated by cause and effect in the ECM.
Posted on: 2014/11/9 17:36
PeteK Re: 90 C4 Reasons for not getting a mph reading
Pluck the speedo sensor out, and shine a light into the speedo gears. I see more gear failures than sensor failures.
Posted on: 2014/11/10 12:50
If you have the VSS pulled out, use a cordless drill to drive it and see if you get a reading on your dashboard.
Posted on: 2014/11/10 13:28
I like the gears solution a lot... they are only plastic.
Great to see you back, Pete!
Posted on: 2014/11/10 17:24
