MikeB52 | Doug Rippie Spring kit? Thoughts? Experience? | ||
Does anyone have or has anyone had the Doug Rippie coilover spring kit on their cars? I just picked up some 19 inch wheels (big I know, but I got a good deal). My concern is that the car will sit too high and look "donked out". Any southern folks out there will know what I mean. Anyway, I've been looking at coilover kits and this seems to be a decent kit without a astronomical price tag, at around 950 bucks. Anyone have anything for or against this kit?
Posted on: 2016/3/28 22:18
BillH | Re: Doug Rippie Spring kit? Thoughts? Experience? | ||
Doug is very............very well known in the racing community. Been doing Corvettes forever.
Since your main goal is chassis height (and not set up for hard track driving) a less expensive kit like this should work well for you. |
Posted on: 2016/3/29 0:34
Matatk | Re: Doug Rippie Spring kit? Thoughts? Experience? | ||
If you're not sure, you can just try lowering the rear first. You can test it on the stock bolts, but they make a lowering kit through any of the vendors that is pretty inexpensive. That might be an avenue to check out.
Posted on: 2016/3/29 11:32
BrianCunningham | Re: Doug Rippie Spring kit? Thoughts? Experience? | ||
What is the tire diameter?
If you keep the tire diameter by using a lower profile tire, then you're not going to lower the car at all. |
Posted on: 2016/3/29 15:37
MikeB52 | Re: Doug Rippie Spring kit? Thoughts? Experience? | ||
I believe I'm still using a 35 in the rear and 40 in the front for profile on the tires. I live in new England and our roads suck. I was originally going to just try lowering the back with the bolts but I heard the handling is sacrificed as it takes the rake out of the car. 950 isn't bad, plus it'll be a coilover setup like I wanted in the first place. I don't race so I dont need anything too crazy. Just enough to have fun on the onramps with haha
Posted on: 2016/3/29 15:41
1994 Vette Admiral Blue 6 speed |
My post from the other coilover thread
Posted on: 2016/3/29 17:02
Sounds legit to me. I'll order them up tonight! Thanks guys! Any advice on wheel bearings? Gonna do them while I'm in there. Are the moog ones junk?
Posted on: 2016/3/29 21:50
Sounds like the cheapos work so long as they're broken in.
Put some easy miles on the before having fun |
Posted on: 2016/3/30 16:25
GOLDCYLON | Re: Doug Rippie Spring kit? Thoughts? Experience? | ||
The Timken bearings are pretty good and the DRM coil overs are an awesome mod |
Posted on: 2016/7/10 4:18
GOLDCYLON - 91 ZR-1 #2014 380 P&P&PCed,Ported Heads,Jeal headers,/Corsas/FIKSE FM-5s /LED TLs, HID Projectors,/R Baer Eradaspeed Rotors with Wilwood 6 piston front calipers |
bogus | Re: Doug Rippie Spring kit? Thoughts? Experience? | ||
Check RockAuto.com for the wheel bearings.
Posted on: 2016/7/10 20:31
