586 user(s) are online (48 user(s) are browsing Forums)
mojo92 how do you reset this
Tifton,Ga.
58 Posts
How do you reset the ECM,I just got my new injectors and I need to reset the ECM. Also a friend of mine that knows everything about everything told me today that my ECM was bad and that is why my car runs the way it does.
Posted on: 2008/9/20 19:22
NC Kid Re: how do you reset this
North Carolina
1671 Posts
If you unplug the negative battery cable for 15 minutes, it's suppose to reset itself.
Posted on: 2008/9/20 20:20
pianoguy Re: how do you reset this
I've also been told to turn the lights and radio on to drain any minute residual charge from the system.
Posted on: 2008/9/20 20:31
Qack Re: how do you reset this
274 Posts
Or turn the ignition key to on -- after you disconnect the battey.
Posted on: 2008/9/20 21:12
Schrade Re: how do you reset this
ECM and other codes CCM, ASR/ABS, DERM go away this way...
http://www.corvette-guru.com/modules/ ... php?topic_id=5237&forum=1
Posted on: 2008/9/21 0:01
bigsarge Re: how do you reset this
4 Posts
When my ECM went bad in my 89 coupe, the car would barely run at startup and low speeds. You could smell gas coming out of the exhaust. It would throw no codes either.
Kevin
Posted on: 2008/9/21 0:56
mojo92 Re: how do you reset this
Tifton,Ga.
58 Posts
Just to let you guys know , I have to bad injectors also. So keep that in mind when trying to help me. Where can I get a ECM ?
Posted on: 2008/9/21 2:09
bogus Re: how do you reset this
don't replace the ECU until you fix the damned injectors. You are throwing good money after bad.
Posted on: 2008/9/21 4:03
Tifton,Ga.
58 Posts
SORRY didn't mean to upset you Bogus !! I didn't say I was going to get a ECM yet I was going to change injectors first anyway. I just want my car fixed and I have alot of people telling different things.
Posted on: 2008/9/21 17:26
North Carolina
1671 Posts
I upset Bogus alot.
Posted on: 2008/9/21 17:53
no, you didn't upset me, all I was saying was get it fixed, one potential issue at a time.
With your 91, the main way to tell if the ecu is bad is if it's not talking to the CCM.
Posted on: 2008/9/22 14:39
NC Kid wrote:
I upset Bogus alot.
no comment.
Lichen Re: how do you reset this
Scottsdale, Arizona
166 Posts
I thought that the ECM reset itself within a few miles.
Posted on: 2008/9/23 1:34
no, it will not. It will store a history code until otherwise cleared.
Posted on: 2008/9/23 2:08
Some codes will erase from memory after x-number of drive cycles with no fault detections.
Possibly only CCM codes and ABS/ASR and DERM codes will do this, and not PCM/ECM codes - I can't remember which ones do (so says FSM)...
Posted on: 2008/9/23 3:13
