311 user(s) are online (208 user(s) are browsing Forums)
The ...
flyboy increased ratio roller rockers
I'm wondering how exactly does a higher ratio rocker arm affect the valvetrain? I'm assuming the pushrod is moved closer to the fulcrum of the rocker causing a higher valve lift. Does it also affect duration, reliability? How about valve noise due to a more aggressive opening and closing? I heard they give the engine a "lopey" idle. One company claims significant power with a 1.6 intake, 1.5 exhaust. What would they do for my mostly stock '91 L98 (straightend exhaust,T.C.3.07). Thats a pretty good chunk of change for something that may or may not do me some good. I won't be changing camshaft anytime soon. Any one have any experience on this?
Posted on: 2008/11/1 2:18
jsup Re: increased ratio roller rockers
1778 Posts
More lift, faster ramp.
Shouldn't change the idle
I hear 1.5 to 1.6 RRs are good for 10-15HP
Don't forget the springs may have to be changed too.
Posted on: 2008/11/1 2:22
AKS_Racing Re: increased ratio roller rockers
62 Posts
Probably more like 5-7HP on a stock cam vette. And you can run the factory springs, though your springs may be tired depending upon mileage.
Aaron
Posted on: 2008/11/1 3:12
1778 Posts
Aaron
Thanks, I always suspected that 10-15 was over rated.
No coil bind going to 1.6? Just wondering.
Posted on: 2008/11/1 3:30
pr0zac Re: increased ratio roller rockers
i wouldn't do a split rocker ratio cause your cam already has a split. that is geared more for the old school cams that were like 280/280 .480/.480 and every new cam has a longer exhaust duration and usually a higher exhaustlift.
Posted on: 2008/11/1 12:30
flyboy Re: increased ratio roller rockers
Thanks for the input. I believe your right, P. According to my notes the cam specs are: @.050" lift in./ex. w/1.5 rockers .413"-.428", 202-207deg. lobe sep114.5.
Posted on: 2008/11/2 1:58
cuisinartvette Re: increased ratio roller rockers
The TPI guys that use the 1.6 typically like them on the intake only. For some reason putting them on the exhaust also tends to give it a slightly rougher idle than stock.
Honestly it isnt worth the money for what tiny gains you may get. Save up and do a H/C. The money spent for maybe 2-3deg dur. gain and what, maybe +.030 lift..Nah.
Posted on: 2008/11/2 2:34
