Josh | TFS head information for the AFR/TFS head comparison | ||
I've posted this in a couple different spots, but I think it deserves it's own post.
See the whole comparison thus far here: http://www.corvette-guru.com/modules/ ... php?topic_id=7225&forum=1 I got the information regarding the testing of my TFS 195 CC heads. Here's the E-mail I got from the shop: Hi Josh, They did arrive and I already have a bunch of information for you. First off they are 100% ported, not just a bowl cleanup like you had alluded to. Guides are narrowed and necked downed nicely and this head had been ported from one end to the other. I might add it was done by someone who looked like they knew what they were doing and had a very neat hand (the walls were straight and the overall execution was certainly above average). The porting might not have been as obvious to you because the heads were glass-beaded when they were freshened disguising some of the finish sandroll marks that are clearly evident when you look closely. Finished intake port volume 205 ccs Intake Flow .200 @ 140 .300 @ 200 .400 @ 245 .500 @ 274 .550 @ 280 .600 @ 282 Exhaust port finished volume 76 ccs .200 @ 108 .300 @ 144 .400 @ 176 .500 @ 190 .600 @ 204 Combustion chamber volume is very small @ 57 ccs (just under actually like 56.8 actually) The TFS heads are much better heads than I thought, so it will definitely make this an interesting test. The idea of AFR winning by a landslide doesn't seem as likely to me now as it did a couple weeks ago. Time will tell. The short block is in the car as of tonight, so the project is moving along. |
Posted on: 2009/2/19 3:16
BeachBum | Re: TFS head information for the AFR/TFS head comparison | ||
Thanks for sharing Josh....
Why would somebody try to hide the porting work they did on the cylinder heads ? Seems like a silly waste of time.... its not like anybody will check once they're on the motor.... |
Posted on: 2009/2/19 4:38
863 cubic inches of C4 & C6 muscle C6 Corvette Z06 - Lemans Metallic Blue C4 Corvette 436 - Pure Black http://www.cardomain.com/ride/3933547 ... chevrolet-corvette/page-1 |
Josh | Re: TFS head information for the AFR/TFS head comparison | ||
I don't think anyone was trying to hide anything. I bought the heads used, and before installing them I had them freshened by a shop. I never saw the heads before the bead blasting.
Posted on: 2009/2/19 4:52
rickreeves1 | Re: TFS head information for the AFR/TFS head comparison | ||
Posted on: 2009/2/19 21:11
95-Lt1-auto-Polo-Conv, 125hp ZEX N2O dry, LE Cam 226/234 565/565 109LSA, Comp Pro Mag 1.6rr, Patriot Xtreme Springs, PCMFORLESS, K&N, AO Ram Air, 52mm TB, EM LT Headers, X-pipe, Meziere HD EWP, Vigil 2800, TransGo Shift Kit, Pro-Built Trans, 24lb SVO'... |
1989GTA | Re: TFS head information for the AFR/TFS head comparison | ||
Thanks again for doing the test. Looks like a set of well ported Trickflows against out of the box AFR's. It is going to be an interesting dyno test.
Posted on: 2009/2/20 1:37
rklessdriver | Re: TFS head information for the AFR/TFS head comparison | ||
I've hidden lots of port work... There is a cottage industry built on porting heads with acid and/or shot peening hand port work (afterwards) to make them look "as cast" in the oval track and NHRA/IHRA Stock Eliminator world. I know neither is something someone would use a set of TFS heads on but still you never know.... When I first started out with acid porting and other cover up work, I practiced on all kinds of stock SBC and SBF heads we had laying around the shop. Some of those heads I experimented on ended up in truck and van motors we were contracted to build for a funiture moving business. I keep thinking that one day someone is going to take one of those motors apart and wonder how in the heck a set of stock looking SBC 882 smog heads have 185cc intake runers..... -Josh With numbers like that, you have a pretty darn good set of TFS heads. As long as the air speed isn't out of wack anywhere they will most likely give the AFR's a good run for their money on the dyno. Will |
Posted on: 2009/2/20 1:53
CentralCoaster | Re: TFS head information for the AFR/TFS head comparison | ||
Sheesh. While you're at it, did you restamp the serial number pads on the blocks?
Posted on: 2009/2/20 2:09
Thats some funny stuff reckless !! LOL... so you want your new furniture delivered right now sir ? You betcha !!
Posted on: 2009/2/20 3:03
Yeah, I had no idea the TFS heads were what they are. When I bought them I got a receipt from the previous owner that said:
"Gasket match / Chamber clean - $300." I guess the previous owner got a good deal. |
Posted on: 2009/2/20 22:53
