skirlin | Help! What size is the spindle nut? | ||
I started the tear down for replacing the bearings and ujoints and ran into a problem. I have a 1992 coupe. I don't have a socket the right size for the spindle nut. 1 1/4" is too small and 1 1/2" is too big. I will be going to the auto parts place tomorrow to get the spindle washers and will pick up a socket when I am there. Any help would be greatly appreciated. Thanks, Dave.
Posted on: 2009/3/20 3:31
There is no point in living if you can't feel alive. |
vetteoz | Re: Help! What size is the spindle nut? | ||
36mm
Posted on: 2009/3/20 6:19
bogus | Re: Help! What size is the spindle nut? | ||
Also, when you retighten the spindle nut, do so to 200 ft-lbs. It's a bitch... I know...
You will also need to get a couple extra T-55 torx sockets. I recommend this because those suckers can be uber-tight... and it's not uncommon to break a socket or two. It might help if you spray the outside of those bolts with a PB Blaster type of penetrating oil. |
Posted on: 2009/3/20 12:44
CentralCoaster | Re: Help! What size is the spindle nut? | ||
Yup, 36mm. Crack it loose before you remove the ebrake cable. The posi alone won't keep it from spinning.
Posted on: 2009/3/20 15:07
WW7 | Re: Help! What size is the spindle nut? | ||
If you want a cheap 36mm socket go to Advance Auto, they have one for about $6.00, since its not used much these work fine...WW
Posted on: 2009/3/20 22:36
