255 user(s) are online (207 user(s) are browsing Forums)
CorvetteBob heater hose crossover needed?
1409 Posts
Hi guys, still been putting in some time on my vette, but also taking care of business otherwise. I'm looking at changing out my heater hoses. The top hose on my '88 has a
5/16" crossover tube running to the intake manifold, just in front of the distributor. Is this necessary? What happens if I eliminate it and just run a regular heater hose to the water pump? Thanks for your help...
Posted on: 2009/4/29 3:59
bogus Re: heater hose crossover needed?
That's a steam vent from the back of the intake. I would worry you might get vapour lock type of effect if you block it off.
The heating system is designed to stop air bubbles from forming. And with as prone to hot running that these cars are, I wouldn't mess with the design.
Posted on: 2009/4/29 4:43
CorvetteBob Re: heater hose crossover needed?
1409 Posts
Thanks very much. The tube stays!
Posted on: 2009/4/29 6:10
convas Re: heater hose crossover needed?
12 Posts
Mine was taken out by the previous owner or maybe when it was converted to RHD and does not seem to have caused any issues for me, been running that way for about 16 years now.
Posted on: 2009/4/29 8:47
anesthes Re: heater hose crossover needed?
Boston, MA
Mine was removed when I threw the TPI setup in the dumpster.
Was a strange vette thing anyway. The Fbody didn't have such a thing and they ran fine.
-- Joe
Posted on: 2009/4/29 11:07
dan0617 Re: heater hose crossover needed?
-- Joe
Ooh, so it's a 'vette only part. In that case, you can probably sell it for a couple thousand dollars. Otherwise, it's worthless. I would think it would be less likely to get a vaporlock when refilling the antifreeze system with that hose intact, but if done right you won't have a vaporlock anyway.
Posted on: 2009/4/29 12:55
vetteoz Re: heater hose crossover needed?
convas wrote:
Mine was taken out .... been running that way for about 16 years now.
Same here , removed it and just plugged hole on every one I have had.
One less place to leak
Posted on: 2009/4/30 8:23
