gascaleman | Wheel info | ||
Can anyone give me specs for wheels. I have black 89 Convertable not Z51. I need specs, I know 17 in. need width, backspace and lug pattern so I can purchase some heels. My car does not have factory wheels and I want to find someting that will look good and different from the other Vettes running around with stock, Z06, etc wheels. I am new here so be patient with me, any help will be appreciated. Thanks
Posted on: 2009/6/21 17:38
1Fast04Vert | Re: Wheel info | ||
All vettes use the same bolt pattern (5x4.75 I dink). Not sure about the front, but the rears should be a 50mm offset or very close to that. Maybe 36mm offset on the fronts??
Posted on: 2009/6/21 18:37
captmike13 | Re: Wheel info | ||
88-96 base
8.5"/2 - 56mm/25.4 = 2.05" 9.5"/2 - 56mm/25.4 = 2.55" Here ya go. Hope this helps. Check out the faq section about our cars. http://www.corvette-guru.com/modules/ ... php?topic_id=1377&forum=1 Welcome aboard. |
Posted on: 2009/6/21 20:45
bogus | Re: Wheel info | ||
If you go to www.tirerack.com or one of the Corvette wheel specialists, you will find they match the wheel to the vintage. That will help a ton.
Others will chime in with who they have dealt with, but I just got some American Racing Torque Thrust M's from Tire Rack. Ooohh... nice... |
Posted on: 2009/6/21 20:48
polish41 | Re: Wheel info | ||
Posted on: 2009/6/21 21:19
If your not living life on the edge your taking up to much space. |
gascaleman | Re: Wheel info | ||
Thank guys. From your info I have found that the wheels that are on my car are Enkei brand, they are 5 spoke 2 piece wheels (Center section is bolted to the rim) Wheel is natural aluminumand centers are painted gold. Thay have some curb scars and a couple of small dents in the outer edge. Are they worth fixing and some paint chipping on the centers.? If I decided to fix them will the bolts actually comeout so I can divide the wheels to have centers powder coated and polish wheels. Thanks again you guys are somethng else.
Posted on: 2009/6/22 1:05
Matatk | Re: Wheel info | ||
Throw up some pics.
They are worth fixing if you like them. That's the bottom line. I bought a set of rims for my 89 off ebay and I like them a lot. A few of us have. Cost to fix each rim you've got is likely 125-150 a piece. Or you could sell those and buy a new set to your liking for around $500-1000 depending on what you want. Decisions, decisions..... Matthew |
Posted on: 2009/6/22 13:12
