187 user(s) are online (139 user(s) are browsing Forums)
1969 through 1976 Corvette.
mojo92 Need help removing paint
Tifton,Ga.
58 Posts
I just got another set of factory wheels from a guy today. He painted the wheels with spray paint (black). How do I get the paint off so I can repaint them right. Keep in mind that they have tires around them, I don't want to have them taken off then put back on. So I need something thats good,fast,cheap and gets the job done..(sounds like a girl I know to well ). Also what sandpaper would I use to get them ready for new paint?
Posted on: 2009/7/22 5:40
DreamRide Re: Need help removing paint
Springfield, TN
226 Posts
Depends on what type of paint you're going back with. If you're spray bombing you can wet sand them down with 220 grit. If you're going to use real paint they'll have to be stripped completely of the PO's spray bomb, because any paint with a reducer and/or hardener will eat it off and then you've really got a mess.
That is unless they've come up with a new real paint I haven't heard of yet.
Posted on: 2009/7/22 11:56
Yeah well.........
pianoguy Re: Need help removing paint
They say that old brake fluid is mankind's greatest paint remover, might be worth a shot.
Posted on: 2009/7/22 12:13
BillH Re: Need help removing paint
Actually, I have to agree and disagree with Donnie (Dreamride). 220 wet sand is the way to go if you want the wheels to look decent.
Any chemical strippers would probably eat the wheels unless they're steel. And I wouldn't want it on the tires.
The best way would be to remove the tires and soda blast, yea, costs a good bit.
"good,fast,cheap and gets the job done" is impossible unless you remove the "cheap". Sanding isn't fast but is good and gets the job done.
You don't have to go to bare metal but do need a good skuffing, blend in any chips in the paint and remove any road grime/grease. Put a shot of Dawn in the sanding water.
You can shoot 2 part paint over rattlecans, I do it a lot.
Donnie, the pics you saw of my helmit,etc. had PPG 2 part urathane shot over quite a few different rattlecans.
Mojo, you may want to take a look at Duplicolor wheel paint in the rattlecans, I did the wheels on my race trailer and it really holds up.
Posted on: 2009/7/22 13:14
That will bubble the new paint, Brad, if you don't get it completely off (hard to do on a wheel).
Posted on: 2009/7/22 13:15
Flashman Re: Need help removing paint
Tampa Bay, Florida
174 Posts
Hi All,
I used gel paint stripper from home depot to strip the clear coat on my aluminum wheels on my 86 vette. It worked great. I used a brush to paint it on. It will wrinkle the paint in 15 minutes. Then wipe it off. I also sanded them and polished the wheels. Dont get it on plastic or rubber surfaces. That is the fastest and cheapest way to do it. If the paint on the wheels are fresh, try laquer thinner. Also, if you are going to paint or clear the wheel. Use high temp paint or the clear will yellow when the wheels get hot from braking. Good luck.
Joe Flash
Posted on: 2009/7/23 3:42
That's interesting, Joe. I have some HD stripper laying around the shop. I'll have to paint some scrap aluminum and try it.
I agree on the hi temp clear, I know the Duplicolor wheel paint is hi temp.
Posted on: 2009/7/23 13:11
1Fast04Vert Re: Need help removing paint
I also used paint stripper on 2 sets of 95 sawblades and it stripped the wheels in just 5 minutes and then I hosed off the stripper and all of the paint. I used aircraft paint stipper from Lowes/Home Depot as it dos not harm aluminum, however the can says it is harmful to rubber. It will take the paint of off anything, everything, so be very carefull, especially over spray if you use the rattle cans. After I used the stipper then some fine steel wool and Blue Magic metal polish and they shined up like new.
Posted on: 2009/7/23 13:58
SSPerformance Re: Need help removing paint
Southern New Jersey
16 Posts
Just about any chemical stripper will harm the rubber. Chemical strippeers are great but if you don't completely remove them they will cause problems with the new paint.
I am a fan of soda blasting. Will not harm the aluminum and cleanup is a breaze. They mignt beable to do it with the tire on the wheel. Check with someone that does soda blasting.
Good Luck
Posted on: 2009/7/23 16:10
