118 user(s) are online (64 user(s) are browsing Forums)
CorvetteBob Removing the IAC?
1409 Posts
I was just reading another post on IACs and
it sounds as if you guys are familiar with taking them out.
I'v tried to do it, but I don't wanna bust up the housing
or anything else. It seems pretty tight in there. How do you guys do it?
Posted on: 2009/10/12 4:12
bogus Re: Removing the IAC?
It's really not that hard... it is tight, but if you put a socket on it, and use an extention, with a ratchet.
Give it a good whack and it will come off.
If you run into issues, removing the TB will help. And really, it won't hurt. I mean, the inside of the TB gets all gnarly anyway.
Posted on: 2009/10/12 5:51
CentralCoaster Re: Removing the IAC?
I use a large crescent wrench. It can stick pretty good the first time, so not a bad idea to pull the TB to get at it better. You're 4 bolts and two clips away.
Posted on: 2009/10/12 14:27
iCorvette Re: Removing the IAC?
302 Posts
good time to bypass the coolant, and reset minimum air and TPS, baby tune up...
Posted on: 2009/10/12 20:42
Vetron87 Re: Removing the IAC?
Granger, Indiana
1988 Posts
Pull TB get a FelPro gasket kit. Clean and replace all the gaskets in TB. Perfect time to clean TB and Plenum. Check IAC connector carefully/mine was brittle and connector was cracked. Reset Trottle Positioning Sensor@ .525 @ Idle.with voltmeter. Inspect and clean IAC. Do not soak motor section of IAC. Haynes Manual preset pintle @ 1 1/8" from gasket to tip of pintle. Hope this helps.. Ron
Posted on: 2009/10/13 0:57
CorvetteBob Re: Removing the IAC?
1409 Posts
Thanks Ron, it does help. Do you have a part # for the Felpro gaskets?
Posted on: 2009/10/13 4:17
