169 user(s) are online (121 user(s) are browsing Forums)
anesthes AFR engine combos
Boston, MA
This is from AFR's website.
I'd love to know what the cam specs were on these puppies. If you look at the hp and torque even at 2500 RPM, this is a killer combination.
Anyone happen to know the full cam specs?
406ci SBC
HP=550
Heads: AFR CNC Cyl Heads 210cc Race Ready
Compression: 10.3:1
Carb: 750 cfm
Ignition/Timing: MSD HEI Billet Distributor 36* Timing
Cam: Lunati Hyd. Roller Cams 232*/ 242+ .560-.570 lift w/ 1.6 rockers
Exhaust 1 3/4" Headers
Fuel: 93 octane pump gas
RPM Torque H.P.
2500 463 220
3000 468 267
3500 457 304
4000 465 354
4500 534 457
5000 540 514
5500 510 534
6000 483 551
AFR has another example with a solid flat tappet and 195 heads that makes even more power. (570).
-- Joe
Posted on: 2009/8/31 17:44
BrianCunningham Re: AFR engine combos
not sure, but here are the full articles
http://www.airflowresearch.com/articles.php
here's the article that sold me on the new AFR Eliminators
615hp 383ci
http://www.hotrod.com/techarticles/en ... ngine_upgrades/index.html
Posted on: 2009/8/31 18:28
1989GTA Re: AFR engine combos
61 Posts
I like the build that Mark Bychowske did with a 370 cubic inch LT1. I believe it was 476rwhp and 402rwtq. Looking at the dyno graph I think the horsepower was still rising at 6500rpm when it was shut off. Now if I can only duplicate that motor.
Posted on: 2009/9/1 0:01
dan0617 Re: AFR engine combos
I know I'm pleased to death with my 383, high compression, 230/236 cammed, AFR 195 street ported head engine. I can only imagine what more cubes, more cam, and 195 comps would feel like. Wish I could afford a 434 with about a 252/260 cammed engine with AFR 235's on top.
Posted on: 2009/9/1 0:53
tpi421vett Re: AFR engine combos
Salt Lake City Utah
125 Posts
Hi Joe, I have a friend here locally that is a bracket racer. He had some W.P sportsman heads that were ported. It is a 74 Nova 406 sbc 12.0 compression, 252/260 solid roller,Edelbrock Victor and a 850 carb. He was running 12.20@109 in our crappy DA (6000-9000ft). He swapped for some race ready AFR 210's on it (not the comp 210's) and now he runs 11.50's @116, just from a head swap.
After porting the W.P heads, the port volume was about the same.
Get some AFR's, and you won't be disappointed!
Posted on: 2009/9/3 5:46
08 C6 LS3,3LT,Z51,A6,NPP
450ci now with AFR 235...
anesthes Re: AFR engine combos
Boston, MA
Sounds good.
Yeah I'm planning on the 195 eliminators. Probably mill to 60cc chambers to get the compression up.
I'd like a solid roller. I'm just a little weary about it because I've heard of a lot of failures at idle. I'd like to stay away from hydraulic though because of lifter pump up and bleed down.
-- Joe
Posted on: 2009/9/3 16:28
BeachBum Re: AFR engine combos
751 Posts
Here is a link for a nice set-up.... he's accessible to talk to you as well.
Its a 418 sbc.... curve was still rising when they shut it off..... probably makes 570ish up at around 6000-6200 rpm, but not sure. Look at the torque curve.... extremely stout across the entire rpm range, especially for such a docile hyd roller cam. I think he got his heavy chevelle into the 10's with that set-up.
http://www.chevelles.com/forums/showthread.php?t=218368
There is another guy with a 414 sbc, basically identical to the above set-up, but he's running E85..... made over 600 HP with basically the same hyd roller cam as above. Power was all in by early 6000 rpm. I can dig-up that torque curve somewhere if you're interested.
Posted on: 2009/9/3 20:38
pr0zac Re: AFR engine combos
that motor sounds like its a little lame for what it is? i had a lot less cam, cubes and compression and out mph'd that in my vette..
Posted on: 2009/9/4 1:58
anesthes wrote:
Sounds good.
-- Joe
i have bought the lifter set that comes with the spider and dog bones from gmpp in a few different motors i have put together and have had great luck. i have seen summit lifters collapse within a short period of running. i have had many speed pro lifters blow on me. i switched to the new gm lsx lifters for my 383 setup because i have heard good things about them and they were $115 for the set.
Posted on: 2009/9/4 2:05
751 Posts
But, did you do it in a 6000-9000 ft DA ?
If that fella in the Nova drove off that mountain to a sea level track, it would run another 5 mph minimum and probably more like 8-10 mph faster. An 11.50 car at that elevation & DA is an easy 10 second car at sea level.
Just food for thought.
Posted on: 2009/9/4 2:25
Boston, MA
I've had issues over the years with Comp hydraulic roller lifters in OE roller blocks.
However, my 400 isn't an OE roller so I need to run retrofit either way.
-- Joe
Posted on: 2009/9/4 10:22
PeteK Re: AFR engine combos
pr0zac wrote:
anesthes wrote:
Sounds good.
-- Joe
Anyone have a link for the lsx lifters? I need to purchase a set or 2.
Posted on: 2009/9/4 11:49
Posted on: 2009/9/4 20:21
Salt Lake City Utah
125 Posts
Beach nailed it! This isn't a sealevel deal. This is up here in the stratoshpere!!! Uncorrected numbers!
Posted on: 2009/9/6 6:18
