383tpimachine | 4L60e | ||
I have an 85 vette and im tired of the 700r4. I will be switching to the LS1 pcm by summer hopefully and will opt for the 4l60e connector. I have a tuner but need the tranny
so my question is: What would it take to make a 95-96 truck 4l60E work in my vette? I would think its as simple as changing the tailhousing right? |
Posted on: 2009/11/20 3:48
bogus | Re: 4L60e | ||
I know there are differences in the 700R4 between the Vette and other applications.
What I don't know is if that's the case with the 4L60E. Beyond that, mechanically as far as installation is concerned, should bolt in, after swapping the tail shaft. I do wonder if the truck version has difference like shaft sizes and such. PeteK would be the one to answer. |
Posted on: 2009/11/20 5:08
383tpimachine | Re: 4L60e | ||
Thats what I was thinking. Ill wait for him to chime in.
700r4 there are different valve bodies between apps. i think. |
Posted on: 2009/11/20 5:27
vetteoz | Re: 4L60e | ||
Depends on when the housing on the truck trans changed; I believe the later "E's" (LS1's )have a 6 bolt housing ; not 4 bolt like 4L60.
Posted on: 2009/11/20 5:40
its off a vortec 350 not a 327.
the 327 started in 97 i believe |
Posted on: 2009/11/20 5:52
vis_croceus | Re: 4L60e | ||
Any reason you can't just use a 94-96 vette 4L60E?
Posted on: 2009/11/20 9:09
iCorvette | Re: 4L60e | ||
plenty of them |
Posted on: 2009/11/20 14:56
Im looking for one but so far all I have come up with locally is this one |
Posted on: 2009/11/20 17:52
1989GTA | Re: 4L60e | ||
Not sure if this will help but I used a 4L60E out of a 1995 truck for my 1989 TPI GTA Trans Am. All I had to do to was change the tail housing for it to bolt right up.
Posted on: 2009/11/21 0:24
I figure this will be as east. But thats for a straight axle. just wanting to make sure PETEK where art thou |
Posted on: 2009/11/21 0:51
bump
Posted on: 2009/11/22 22:46
PeteK | Re: 4L60e | ||
It should. Swap tailhousing, and chop down output shaft 3/4 inch. Truck converter would likely be a touch tighter than a stock 85, but the 85 converter will work fine with the 95. |
Posted on: 2009/11/22 23:00
I was told 85 stall was 2000-2200. Anyway I will be able to confirm this when I swap? I want to keep my stall below 2500 until I get another car
Posted on: 2009/11/23 2:25
The converter will have a sticker with a 4 letter code. That code will tell you the stall. |
Posted on: 2009/11/23 2:29
