153 user(s) are online (79 user(s) are browsing Forums)
lindenbob Bosch 3 Injector installed Pic +
Pa
16 Posts
Installed my Bosch 3 Injectors from FIC last evening. Only did a 15 minute run but plan on a road test today. Here is a pic of them installed plus I thought ya'll might like to see the Sterling ceramic coated manifolds.
[img align=right width=300]c4,corvette,lt1,corvette show[/img]
[img align=right width=300]Sterling Jet_Hot Install[/img]
Posted on: 2009/11/21 7:45
Matatk Re: Bosch 3 Injector installed Pic +
22812 Posts
Excellent! Glad you got it buttoned up without a problem.
Posted on: 2009/11/21 12:55
1Fast04Vert Re: Bosch 3 Injector installed Pic +
It would be nice if all jobs were as easy as LT1/4 injectors. The manifolds look great.
Posted on: 2009/11/21 13:42
lindenbob Re: Bosch 3 Injector installed Pic +
Pa
16 Posts
Thanks. Yes injectors are a snap. Now the exhaust manifolds removal. That is one of them jobs half way thru you ask yourself why am I doing this?
Posted on: 2009/11/21 22:43
383tpimachine Re: Bosch 3 Injector installed Pic +
Corpus Christi
976 Posts
L98 injector swap is a pain. glad I changed to a HSR intake
can you notice a change in the driving?
Posted on: 2009/11/21 23:16
pianoguy Re: Bosch 3 Injector installed Pic +
Looks great!!
Posted on: 2009/11/21 23:31
corvetteronw Re: Bosch 3 Injector installed Pic +
Lowell, MI
I was wondering about doing that to my 91's exhaust manifold until I can afford to buy headers. What problems do you run into when not running the heat shields? Do you have extra insulation on the plug wires that are near these manifolds?
Posted on: 2009/11/24 4:43
Pa
16 Posts
For the time, effort and funds to coat the manifolds I wouldn't do it if you are planning to put headers on in the near future. As far as heat, this coating is rated to 1300 F and are coated inside and out which drops the manifold temp from 400-300 degress cooler than uncoated manifolds. The heat shields only cover the sides and warm air rises. So they don't do much for protecting wires to begin with. I will not know if it has any adverse effects until I start doing longer runs in the spring. I have standard 8.5 mm silicone wires and don't figure there to be any problems. You can almost put your hand on the manifolds while it is running. The ceramic coating channels most of the heat right out the exhaust.
[img align=right width=300]Photobucket[/img]
Posted on: 2009/11/24 10:03
BrianCunningham Re: Bosch 3 Injector installed Pic +
My MSD wires wouldn't fit in the stock looms, so I took the sheetmetal brackets off.
I got sick of getting cut by them.
Posted on: 2009/11/24 14:16
Pa
16 Posts
Now that she is all buttoned up I thought I should post a few more pics. The Bosch 3 Injectors from FIC are very smooth and responsive.
Posted on: 2009/11/29 2:20
