422 user(s) are online (135 user(s) are browsing Forums)
tjpreul Bowling Green plate
Under the hood there is a plate with a Corvette symbol, next to Bowling Green, KY. I have seen on other cars this is a Molbil 1 label. Does anyone know the difference. My car is a '92.
Posted on: 2009/12/27 2:57
bogus Re: Bowling Green plate
they didn't do the Mobil 1 plate in 1992. It was a year or 2 later.
the plate you are referring to is the "made in" plate.
Posted on: 2009/12/27 2:59
tjpreul Re: Bowling Green plate
Yep, that is the plate. I was wondering because my '92 came with Mobil 1. I like the Bowling Green one better.
Posted on: 2009/12/27 3:05
you can always get mobil 1 decals...
Posted on: 2009/12/27 3:20
The guy I bought mine believed in a brandx, and so that is what was in the car. It has 140k, so I didn't want to switch. I think it is best to keep running the same. Until I rebuild the motor.
Posted on: 2009/12/27 3:28
it won't matter.
What is brandx?
Posted on: 2009/12/27 4:14
Pennzoil, I prefer Valvoline.
Posted on: 2009/12/27 14:04
BillH Re: Bowling Green plate
jpg  IMGP0632.jpg (0.00 KB)
Posted on: 2009/12/27 15:15
damien89 Re: Bowling Green plate
53 Posts
Even 89's had that plate
Posted on: 2010/6/20 11:44
Tre57 Re: Bowling Green plate
Portland, OR
104 Posts
IIRC the Bowling Green plate was used from 84- early 93 and the Mobil-1 from late 93-96.
Posted on: 2010/8/16 23:52
93 AT Coupe
Portland, OR
104 Posts
Posted on: 2010/8/16 23:56
93 AT Coupe
PLRX Re: Bowling Green plate
SoCal
212 Posts
96 dont have the plate, they put the oil info on the oil cap.
Posted on: 2011/9/25 16:23
