179 user(s) are online (123 user(s) are browsing Forums)
The ...
BrianCunningham GM issues 2nd recall for Corvette roofs
ouch!
ast Updated: December 28. 2009 3:00PM
David Shepardson / Detroit News Washington Bureau
Washington -- General Motors Co. said Monday it is recalling 22,000 Chevrolet Corvettes over concerns that the roof may fly off the vehicle -- after a 2006 recall didn't fix the problem.
The new recall applies to 2005-2007 model year Corvettes and Corvette Z06 models.
GM told the National Highway Traffic Safety administration that the adhesive between the roof panel and frame may separate. GM will install a redesigned roof panel as a result.
Advertisement
"If there is a partial separation, the driver may notice one or more symptoms, such as a snapping noise when driving over bumps, wind noise, poor roof panel fit, roof panel movement/bounce when a door or hatch is closed, or a water leak," GM said.
This is the second attempt by GM to fix the problem.
In May 2006, GM told NHTSA that it was recalling 30,793 2005-2006 Corvettes over concerns that the vehicles, "primarily in hot and humid climates, have a condition in which the adhesive between the roof panel and the frame may separate."
GM said the problem was due to inadequate bonding strength, following reports of at least 11 roof separations. GM's 2006 fix was to insert adhesive foam -- and, if necessary, replacement of the roof.
In March, an inquiry from Japan's Ministry of Land Infrastructure and Transport about a Corvette roof that was repaired after the 2006 recall prompted GM to look at its U.S. warranty claims data for Corvettes.
As a result, GM found 108 claims of roof separation after the foam was added in the attempt to fix the problem.
Now, GM will replace the roofs.
The automaker will begin notifying owners in January and will reimburse motorists who have already gotten their roofs repaired or replaced.
dshepardson@detnews.com (202) 662-8735
http://www.corvetteblogger.com/index. ... 411-3657-AD0F50DDBDAF5D84
http://forums.corvetteforum.com/c6-z0 ... 369957-roof-fell-off.html
Posted on: 2009/12/29 16:01
CentralCoaster Re: GM issues 2nd recall for Corvette roofs
What's a new roof cost? $1500 x ~100,000 cars = $150,000,000
Posted on: 2009/12/29 16:55
BrianCunningham Re: GM issues 2nd recall for Corvette roofs
GM sold 100k Z06's?
Posted on: 2009/12/29 16:59
DaleD Re: GM issues 2nd recall for Corvette roofs
Cuyahoga Falls, Ohio
1389 Posts
From the article, 30,793 cars. About $46M at $1500 per unit.
GM doesn't care, the taxpayers will cover it.
Posted on: 2009/12/29 17:09
Jeffvette Re: GM issues 2nd recall for Corvette roofs
Recall is for all 2005-2007 Coupes. Z06 included.
2005 - 26,728
2006 - 16,598 Z06 - 6,272
2007 - 21,484 Z06 - 8,159
So 79,241 units at 1,500 per roof (Does this include dual roof equipped cars?)
Total $118,861,500
Posted on: 2009/12/29 17:50
Posted on: 2009/12/29 17:56
It would have to. If 25% of those cars came with 2 roofs, you're at $150M.
Posted on: 2009/12/29 17:57
88BlackZ51 Re: GM issues 2nd recall for Corvette roofs
481 Posts
i have a feeling the roofs dont cost GM $1500.
Posted on: 2009/12/29 18:31
No, but that price includes overhead and profit needed to keep the doors open.
If I give away free lemonade instead of fetching my normal 75 cent price per cup, then I am losing 75 cents on every cup, regardless of what my actual cost is.
Posted on: 2009/12/29 19:01
