270 user(s) are online (221 user(s) are browsing Forums)
'W' Series:
5.7L 348ci - 1958 thru 1964
6.7L 409ci - 1961 thru 1965
7.0L 427ci (Z11...
Ultraman Tune up on my 90 question
14759 Posts
I am going to tune up my 90 with 53K. Plugs, wires, cap and coil, rotor. Don't know the history on the car so for a winter project I thought I would start fresh for next season. Should I also replace the ignition module at this time? Should that be part of the normal tune up or not? I appreciate the help, Merry Christmas!
Posted on: 2009/12/21 2:44
bogus Re: Tune up on my 90 question
It's not a normal part for a tune up.
If it's working ok, I would leave it. They don't age out, but they do wear out... and your's can't have enough wear.
Posted on: 2009/12/21 4:33
Matatk Re: Tune up on my 90 question
Test your injectors while you're in there. Have you had any trouble with them? Hard starts, etc?
Posted on: 2009/12/21 12:29
Ultraman Re: Tune up on my 90 question
14759 Posts
Injectors seem ok but I can run a test If I can find the thread on how to do it.
Posted on: 2009/12/21 23:58
Dads90 Re: Tune up on my 90 question
Pearland, Tx
318 Posts
If the injectors are original Multecs, don't run Seafoam thru them. It will kill them. Did mine.
Posted on: 2009/12/30 5:38
jhammons01 Re: Tune up on my 90 question
Posted on: 2009/12/30 5:46
BrianCunningham Re: Tune up on my 90 question
When's the last time the fuel filter was changed.
cheap insurance.
Posted on: 2009/12/30 14:20
14759 Posts
I put it on new about a month or so ago. It needed it!
Posted on: 2009/12/30 23:39
