bigmoe | 94 TB bypass | ||
Someone suggested I do a TB bypass on my 94, similar to the 95 and 96. I understand this cleans up the look a bit. Is there any other advantage to doing this mod other than appearance?
Posted on: 2010/1/7 17:24
tjpreul | Re: 94 TB bypass | ||
Some say horsepower, because it removes the heat from the TB. The lines are to help prevent the blades from "frosting".
Posted on: 2010/1/7 17:42
BrianCunningham | Re: 94 TB bypass | ||
mine's been bypassed for years
no problems. |
Posted on: 2010/1/7 17:57
1Fast04Vert | Re: 94 TB bypass | ||
I started a thread on this topic in CF. It should answer all of your questions.
http://forums.corvetteforum.com/c4-te ... 95-hose-mod-question.html |
Posted on: 2010/1/7 18:05
Ultraman | Re: 94 TB bypass | ||
Will that also work on my 90?
Posted on: 2010/1/7 19:14
bogus | Re: 94 TB bypass | ||
The L98 is a similar concept, except that the hose is smaller at one end than the other. This means you need a reduction coupler.
Posted on: 2010/1/8 4:29
