289 user(s) are online (251 user(s) are browsing Forums)
Horsepower844182 Did a code check
Beaumont, TX
82 Posts
Using the paper clip trick to get to diagnostic mode.
I only got on code "H63". I know the H stands for "History" (old) but what's the 36 for? It was in Module 9 if that's important.
My "Service ASR" light, "Service ABS" light, and "ABS Active" light are all lit right now (have been since I've bought the car). I know the ABS and ASR are tied into each other in a way but does my code have anything to do with the traction control?
Posted on: 2008/1/6 19:25
~Austin~ \´97 Firebird A4 15.86 @ 86 Stock w/ cutout
\´92 Corvette A4 Bored and Stroked 383 LT1 Cammed 468rwhp
Stl94LT1 RE:Did a code check
128 Posts
It's an "opti" code.
DTC #36: Distributor Ignition System High Pulse.
Posted on: 2008/1/6 19:56
Horsepower844182 RE:Did a code check
Beaumont, TX
82 Posts
Hmm Well for one, what's that mean lol and two, I don't think I've had any trouble with that
I figured if the lights were on, there would be a code to go with it. Where are my codes!? lol
My dad said he might have an OBDI scanner so I'm going to try that also tomorrow.
Posted on: 2008/1/6 20:10
CasetheCorvetteman RE:Did a code check
Errrm, no its NOT the optispark, module 9 has got nothing whatsoever to do with the engine management, have another read...
I dont have a service manual for a 92, so im not sure what that code is yet. If its in module 9 its got nothing to do with the distributor i know that much.
ABS/ASR is the antilock brakes and traction control.
Posted on: 2008/1/6 20:23
Beaumont, TX
82 Posts
Actually, he was right, I have code "H63" not "H36" oops ::embarrassed::
Posted on: 2008/1/6 20:52
kentucky_vetter RE:Did a code check
somerset, ky
154 Posts
This might be of some use to you ! http://www.corvettedoctor.com/1992_93_DTC_Codes.html
Posted on: 2008/1/6 22:57
Beaumont, TX
82 Posts
My Chilton's manual says "Code 63 - Oxygen Sensor (OS2), right side circuit open or Cruise system problem (speed error) or Manifold Absolute Pressure (MAP) sensor circuit out of range"
Posted on: 2008/1/6 23:01
CSS996 RE:Did a code check
Mega Guru
Central PA
3644 Posts
Totally unrelated, but DAMN that's a pretty Vette!
Posted on: 2008/1/6 23:05
Currently "Between Vettes".
CFI-EFI RE:Did a code check
Top of Utah
372 Posts
Burn the Chilton's manual. or use it for a wheel chock. The FSM will decipher the codes, and it provides a trouble shooting chart for locating the cause of the codes.
RACE ON!!!
Posted on: 2008/1/6 23:33
bogus RE:Did a code check
Or check this: C4 Guru - 1992/93: Reading CCM Codes
The H63 means "Valve Solenoid Circuit Error." Whatever that means.
Posted on: 2008/1/7 0:03
Beaumont, TX
82 Posts
One question I had was I know the H means it's an "old" code. I was pretty sure I cleared it, drove around the block, and when I tried it again, it still showed up as an old code.
Posted on: 2008/1/7 0:21
"old" code is nebulous at best. Basically, it is a "stored" code. The only way you can get a C code is if you are watching it happen with a scan tool.
I will dig out my helm and check that code. Gimmie a bit, I have to run some errands.
Posted on: 2008/1/7 0:33
RACE ON!!!
CFI-EFI say everything best no matter how he says it. The man is very rarely incorrect, and this instance is no different.
From what the code is, DTC 63 in module 9, which is as Bogus stated above, your going to require the REAL manual, which you can get from the link posted be CFI-EFI above, in order to have exactly what you need right there infront of you when you need it.
Clear those DTCs using the method here: http://www.c4guru.com/articles/CCMCodePull.pdf (page 11 i believe) and see what occurs. Check all the connections and have a bit of a play with the wiring and then start'er up and go for a drive, see if it all works or same DTC.
Posted on: 2008/1/7 7:14
Wrong codes, wrong module.
Posted on: 2008/1/7 7:18
BillH RE:Did a code check
On the 92, almost everything will show up as an "H" except tha C12 (no codes). I think this happens when you shut off the key and any codes get stored.
In module 9, the H63 is Valve Solenoid Relay Fault ( Valve Solenoid Circuit Error on Andy's sheet, same thing).
Yep, looks like that will trigger the ASR/ABS lites.
When the ign is on, this realy provides voltage to activete the solenoids and provides a ground path for the "service abs" lamp.
Service ABS and service ASR lites will be on and a code 63 will be set when the Valve Solenoid relay voltage falls to less that 5 volts.
I'd first try and reset that code, go to 9.7 to reset, and see if it comes back and the lites go out.
If not, BURN the Chilton. The diagnosis is on page 5E1-82 in the real manual.
BTW, I want your wheels for my Black Rose.
Posted on: 2008/1/7 16:31
Beaumont, TX
82 Posts
Thanks for the info. Like I said, I'm pretty sure I deleted the code the first time around, and the lights never went off. When I did the check again, the code either came back or was still there. Where is this Valve Solenoid at if I need to change it?
Posted on: 2008/1/7 21:41
Top of Utah
372 Posts
You will never know if it is defective, unless you TEST it. Otherwise, all you are doing is throwing money and parts at the problem in hopes that the "shot gun" method will end up hitting something. A code identifies the circuit or sensor that sent a "bad" or out of parameter reading. It does not state the cause of that bad reading. After the code is identified, you must diagnose the cause of the code. Take an O2 for instance. If you get a code that reports a rich mixture, does that mean the O2 is bad? Or does it mean that because of some, yet to be discovered problem, that there really WAS a rich mixture. The same is true, especially, of codes pertaining to the EGR valve. Seldom, when there is an EGR code, is the EGR valve the cause. The [color=blue:fd6c2b9f79]FSM[/color:fd6c2b9f79] tells how to extract the codes, what circuit or device each code is related to, and most importantly, a trouble shooting chart to help you diagnose and track down the CAUSE of the problem, minimizing the expense of unneeded parts. The book isn't cheap, but depending on the job and the potential for false diagnoses, it can pay for itself in one job. Plus it has a lot of neat reading where you can learn a lot about how the systems in your car work.
RACE ON!!!
Posted on: 2008/1/8 1:26
You will never know if it is defective, unless you TEST it. Otherwise, all you are doing is throwing money and parts at the problem in hopes that the "shot gun" method will end up hitting something. A code identifies the circuit or sensor that sent a "bad" or out of parameter reading. It does not state the cause of that bad reading. After the code is identified, you must diagnose the cause of the code. Take an O2 for instance. If you get a code that reports a rich mixture, does that mean the O2 is bad? Or does it mean that because of some, yet to be discovered problem, that there really WAS a rich mixture. The same is true, especially, of codes pertaining to the EGR valve. Seldom, when there is an EGR code, is the EGR valve the cause. The [color=blue:906514afca]FSM[/color:906514afca] tells how to extract the codes, what circuit or device each code is related to, and most importantly, a trouble shooting chart to help you diagnose and track down the CAUSE of the problem, minimizing the expense of unneeded parts. The book isn't cheap, but depending on the job and the potential for false diagnoses, it can pay for itself in one job. Plus it has a lot of neat reading where you can learn a lot about how the systems in your car work.
RACE ON!!!
Well Said
On thing I've over the years when purchasing a car/truck is add $100 to the money I'm planning to spend for the correct shop manual. And you get to keep them if you sell. I've got manuals and suppliments for 63,64,65, 6 & 7, 76 & 92 Vettes as well as a bunch of Chevy trucks.
Manuals are like tools, once you've got a good one, you can't figure how you lived without it.
Posted on: 2008/1/8 3:52
Like CFI said, you gotta test it. You can't do that without the manual and IF it's bad, you can't replace the unit without the manual.
I put my manuals back down in the shop and am feeling lazy right now. I'll try and check in the morning, it takea a while to find this chit in the manuals sometimes, the location isn't shown on the diagnosis page.
But, Im betting it's behind the driver's seat in the ABS compartment.
Posted on: 2008/1/8 4:04
Yep, youve gotta do all that, and id have to say, if the codes were cleared, when the vehicle is started the MIL lamps should all go out, including the ABS and ASR lamps until you reach the 3mph test, if they are not going out, id say youve got some sort of a short to ground in there, or other electrical issue.
Posted on: 2008/1/8 6:58
Beaumont, TX
82 Posts
Couple of things:
1) I'm aware of the fact that there are a number of things that could cause the code to be thrown, but if I know where to look for the "valve solenoid" then I could maybe trace down a faulty wire or bad ground somewhere.
2) Maybe I'm not erasing the code the right way. I'm pretty sure I went to 9.7, got it to show three dashes, but then I turned the car off and pulled the paperclip out. Should I start the car after getting the dashes? Or what do you mean but "other electrical issue"?
Posted on: 2008/1/8 7:08
1: Its behind the driver seat in the rear compartment.
2: Just unplug the battery and leave it that way for a while, then come back, reconnect and test. The MILs should all light up on start up to show they are working, and they should then go out after 2-3 seconds.
3: If any of the MILs light up and dont go out when they vehicle is tunred on, youve got some sort of issue that the CCM can see wrong with module 9 before the car gets to the 3mph speed for the ABS self test. It should only be able to see wiring faults and/or comunication issues until the selftest.
4: Consider load testing the battery.
Posted on: 2008/1/8 8:12
Top of Utah
372 Posts
Couple of things:
1) Is the "valve solenoid" the next item to check in a logical scheme of diagnosis? The FSM not only provides a trouble shooting chart, it will likely reveal the location of the components in the system you are working on.
2) Erasing codes are covered in the FSM, also. I'm not familiar with your later computer, codes , and operation, so I can't post it.
You will find it is rather easy to waste money, making repairs, without the FSM.
RACE ON!!!
Posted on: 2008/1/8 15:34
Couple of things:
If you got 3 dashes in 9.7, you cleared it. If you leave the paperclip in and turn the key off, then back on. You should see C-12 first, then it will cycle thru 1.0, 4.0 and 9.0, and should show 3 dashes at each one.
I don't think starting the car is necessary for this particular problem.
Unhooking the battery probably won't change anything but it's worth a shot.
Posted on: 2008/1/8 18:08
Beaumont, TX
82 Posts
Yeah, that's what I got. I just don't remember the lights going off. But maybe they did, i'll try again in a little bit
Posted on: 2008/1/8 19:29
Starting the car wont do anything for it. C12 is only related to the CCM, its got no relation with the other 3 modules.
Posted on: 2008/1/9 1:47
Hey Case, I'm not sure I understand what you're saying here. C12 is no codes stored in the CCM but if you have a code in any module the C12 won't show up.
Posted on: 2008/1/9 15:24
HP - Did you read the tech tip I posted? It has all of his outlined in it, as far as reading and resetting codes is concerned.
I need to get my 92 helm to get a feel for the problem you are having. Tonite, I hope, but more than likely tomorrow nite.
Posted on: 2008/1/9 15:26
It does on mine, C12 shows there is no DTCs present in the CCM module (module 1). The other modules are only displayed through the CCM (module 4 being ECM, module 9 being ASR/ABS, and module A being air bag).
Posted on: 2008/1/9 15:59
Beaumont, TX
82 Posts
I got a friend that printed me out a few sheets on the code from something called "Alldata"? He works at a repair shop so I'm assuming that's what they use. It has a step by step check thing too so I'm going to try to give that a go when I get a chance, hopefully tomorrow.
Posted on: 2008/1/9 17:49
AllData is a tool used by shops. it's designed to allow independants to get factory support data. It's expensive as hell.
Posted on: 2008/1/9 20:28
Beaumont, TX
82 Posts
Not if you know where to look ::shifty eyes::
Posted on: 2008/1/10 0:20
Top of Utah
372 Posts
AllData is a "Chiltons" or "Haynes" type of service that shops subscribe to from Auto Zone. I haven't seen any of their trouble shooting charts, but just knowing the source makes me leery. Have you ever found an Auto Zone parts person that knew what they were talking about? I can see the economy for a shop. It would be impossible to keep a FSM for everything that might roll in off of the street. But for a hobbyist with only a couple of vehicles to be concerned with, why trust a second hand source of info?
RACE ON!!!
Posted on: 2008/1/10 0:31
my experience with AllDAta is that they start from the FSM... scan in pages and stuff.
At least that what I have seen on the Corvette images I have observed.
Posted on: 2008/1/10 1:06
OK, agreed. I was confused when you said "other 3 modules" . If I get a C12 when the key is turned on and then go to 1.1 to display any errors, I get 3 dashes.
If any DTC's are present, they show at key on and then show up in the specific modlue as it cycles thru the 3, correct?
Posted on: 2008/1/10 15:30
lesfriendly Re: Did a code check
3 Posts
codes 63 open loop 64 right bank lean what are the causes and what are the fixes?
Posted on: 2011/8/2 0:45
bogus Re: Did a code check
Les,
Welcome!
What year? Mileage? Engine?
The codes change from year to year.
Posted on: 2011/8/2 1:10
