189 user(s) are online (130 user(s) are browsing Forums)
Steve40th Neat little datalogging tool for self tuners.
1114 Posts
Posted on: 2010/2/26 5:47
Ko'u ohana aia ku'a ikaika
Curtis1974 Re: Neat little datalogging tool for self tuners.
Bolingbrook, IL
1070 Posts
That is pretty slick!
Posted on: 2010/2/26 10:02
Purchase date: 11/23/2003
Aboatguy Re: Neat little datalogging tool for self tuners.
My Avatar was redistributed!
498 Posts
(wifi vice cable) Cool!
Posted on: 2010/2/26 11:46
biggrizzly Re: Neat little datalogging tool for self tuners.
That thing is pretty cool, and looks pretty easy to install if you read the .pdf installation instructions. My problem would be learning what to do with it after I installed it.
What I'd like to see is a complete Datalogger and Editor App written for the DROID / iPhone. That would be cool too!
Posted on: 2010/2/26 13:29
CentralCoaster Re: Neat little datalogging tool for self tuners.
Now if you can combine that with that iphone program that uses its internal accelerometer to datalog vehicle speed and acceleration, I'm sold.
Posted on: 2010/2/26 19:00
BrianCunningham Re: Neat little datalogging tool for self tuners.
*Standard router required for Droid™ and Storm2™
3rd box?
Posted on: 2010/2/26 19:09
found one for Android phones
http://trackmaster.trackaroo.com/welc ... 80d114f8232b9657db8511aba
if I get one, guess what's the 1st thing I'm buying
Enable the Speech setting and Dynomaster will speak your speed and times as well as your progress (60 ft, 1/8 mile, 1/4 mile). This allows you to keep your eyes on the road. Speech will also work with a bluetooth headset.
Posted on: 2010/2/26 19:27
There's a similar app for the iphone, but it cann't tap into the ecm either.
Check youtube, it had really good reviews. The accelerometer in the iphone is apparently more accurate than the one in the gtech pro!
Posted on: 2010/2/26 20:03
On my Droid I have a pretty cool App that use the acceleromter, its called aDyno and will capture a ton of information but it won't communicate with the PCM.
Posted on: 2010/2/26 21:03
Posted on: 2010/2/26 21:21
Posted on: 2010/2/26 21:23
498 Posts
Dynolicious
and it works on the Ipod touch too....
Between my datalogger, top speed capture on my GPS and dynolicious.....I'm going to end up in trouble someday....
Posted on: 2010/2/27 0:16
how's this for an upgrade on Trackmaster?
Trackmaster now has Google Street View integration. If you run road rally or you're fortunate to run at Laguna Seca or Thunderhill, you can launch Street View from your session to see a panoramic view of that apex you missed. If your track is not in Street View, encourage them to join the Google Street View Partner Program (it's free) to get their track mapped
Posted on: 2010/6/30 1:01
498 Posts
IPHONE accelerometer may have a slight margin of error[IMG]http://i14.photobucket.com/albums/a342/aboatguy/Car/Harbor%20Freight/dynolicious1071jpg.jpg[/IMG]
Posted on: 2010/6/30 10:30
aknight Re: Neat little datalogging tool for self tuners.
8 Posts
__________________________________________________
My dongle is permanently attached and is quite the conversation piece when I bring it out!
Posted on: 2010/9/10 23:52
