149 user(s) are online (102 user(s) are browsing Forums)
BillH LT1 Balancer - Interesting
Anyone else have their balancer marker like this? Andy, your 92?
And, interesting, the pic of the hub shows a pointer. I just checked, the pointer points directly at the keyway, at least on my 92.
jpg  IMGP0670.jpg (0.00 KB)
jpg  IMGP0671.jpg (0.00 KB)
Posted on: 2010/3/12 21:45
shakedown067 Re: LT1 Balancer - Interesting
119 Posts
I hope to never see that side of my balancer. Sorry, can't help.
Posted on: 2010/3/12 22:11
Aboatguy Re: LT1 Balancer - Interesting
My Avatar was redistributed!
498 Posts
Not on the 92, or two 95 stock balancers I've seenQuote:
Posted on: 2010/3/12 22:35
bogus Re: LT1 Balancer - Interesting
20861 Posts
my balancer looks just like yours, except, no writing on it.
I don't remember what my pointer pointed at! I always marked the pointer and the snout and removed.
Posted on: 2010/3/13 16:28
498 Posts
I thought the markings were what the question was about....
If I misunderstood I'll clarify......every stock LT1 balancer I've seen looks just like yours with the exception of the writing.
Posted on: 2010/3/13 17:54
Jeffvette Re: LT1 Balancer - Interesting
So basically somebody marked the balancer for the 360 degree rotation so they could have a visual mark on where they needed to go.
Posted on: 2010/3/13 18:45
BillH Re: LT1 Balancer - Interesting
JeffVette-So basically somebody marked the balancer for the 360 degree rotation so they could have a visual mark on where they needed to go
Right, it's the marking that I thought was interesting.
I have all the paperwork from 30k miles to today. The only thing done to the car outside of alternator & w/p was a new clutch/flywheel at 60k.
And the first time I took the balancer off it was very tight(normal).
So, I'll never know when or why. I posted the pic cause I didn't think it was factory.
Posted on: 2010/3/13 19:13
BrianCunningham Re: LT1 Balancer - Interesting
pointer yes
marker no
Look like someone's had it apart before.
Posted on: 2010/3/13 20:16
