251 user(s) are online (193 user(s) are browsing Forums)
1st Gear: 2.52
2nd Gear: 1.52
- 13 Bolt ...
BrianCunningham [flood] State of Emergency
http://www.thebostonchannel.com/mostpopular/22840646/detail.html
Feel like I should have put a snorkle on the truck today
3in of water in the basement
main st is shutdown.
on the bright side it's suppose to be in the 70's this weekend
Posted on: 2010/3/15 21:52
pianoguy Re: [flood] State of Emergency
Anti-flood mojo! A friend of mine in PA had a bunch of water in his basement this weekend, and power outages, too. Ick!
Posted on: 2010/3/15 21:56
BillH Re: [flood] State of Emergency
Sucks Brian. Good Luck.
I saw a ShopVac somewhere that has a hose attachment so you could use it like a pump to remove water.
Posted on: 2010/3/15 23:12
BrianCunningham Re: [flood] State of Emergency
no pump plumbed in
using a temp
I've got a hose out a window
I wonder what creatures will sneak in during the night.
Posted on: 2010/3/16 0:14
managed to get out today
entire neighbor hoods flooded out.
Local Dunkin' Donuts underwater
Posted on: 2010/3/16 21:02
1Fast04Vert Re: [flood] State of Emergency
Lowe's sells those and they work great. You can suck water into the vac (or a squirrel out of a tall tree) and once the cannister gets about 3/4 full it pumps it out very quickly thru a garden hose. Well worth the money.
Posted on: 2010/3/16 21:36
got one been using it
the water is low enough so the temp pump will stop working
fill vac, which takes about 2 min
empty vac with pump which takes about 5
repeat,
repeat
repeat
you get the idea of what I was doing today
Posted on: 2010/3/16 23:04
t commuters had the tracks washed out
other stations just gave up
Posted on: 2010/3/16 23:10
Matatk Re: [flood] State of Emergency
22808 Posts
Sucks! How is the basement doing?
Posted on: 2010/3/17 0:18
getting set to vacuum up what's left
almost lost the car last night
went down the stairs and had the 'WTF is THIS' look on her face.
LOL
Posted on: 2010/3/17 1:07
