124 user(s) are online (85 user(s) are browsing Forums)
DaleD Antenna mast on an 87
Cuyahoga Falls, Ohio
1389 Posts
My antenna started clicking when it goes down. I have a new mast. The instructions from Mid-America say remove the bezel take the retaining nut off from the top, and replace. Seems to be impossible. The bezel doesn't come out. I pulled on it and the back of the car raised up. I didn't want to screw something up.
So, I figured I'd ask the gurus. How in the heck do you replace an antenna mast on these cars?
Posted on: 2010/3/25 0:12
bogus Re: Antenna mast on an 87
there should be a special socket that reaches in and gets the castle nut off.
Posted on: 2010/3/25 0:52
DaleD Re: Antenna mast on an 87
1389 Posts
Does the bezel lift out? That thing is on there tight. Is there a trick?
Posted on: 2010/3/25 0:54
if you loosen the bolt, it should come right out.
the mast will then come out when you turn on the radio.
Posted on: 2010/3/25 0:56
1Fast04Vert Re: Antenna mast on an 87
The antenna mast nut has to come off first. It has two little 'dimples' directly across from each other. The antenna mast socket slides down over the mast and will engage those two 'dimples' so you can unscrew the nut. After that turn on the radio while simultaneously pulling the mast and ribbon out.
Posted on: 2010/3/25 1:27
1389 Posts
The Mid-America kit has a tool that is intended to loosen that castle nut. But, here's the problem, that black piece, the bezel, how does that come out?
It's what you see when the antenna is down. I don't know if it's rubber or bakelite. If it's rubber, it's hardened up over the years, but it's that black piece that hides everything else. How do you get that thing off?
Posted on: 2010/3/25 12:19
You don't take that off. The mast slides up thru it.
Posted on: 2010/3/25 12:59
1389 Posts
I'm confused.
I thought the access to the castle nut was from the top of the car. If you're standing at the back of the car, looking down at the antenna hole, you can't access anything if you don't take off that black bezel?
Posted on: 2010/3/25 13:09
DaleD wrote:
I'm confused.
It is as simple as I described in #5 above. The only thing I did not say is that there is a collar on the mast that comes out with it. You have to transfer the collar from the old mast to the new one. I am also confused though as I am not familiar with a castle nut anywhere on the mast.
Posted on: 2010/3/25 13:16
can you post a picture of the antenna in the fender? I am wondering if you have an OEM antenna in there.
Posted on: 2010/3/25 14:34
1389 Posts
I think the confusion comes from where I'm trying to do this. I'm trying to accomplish the swap from the topside of the car. The goofy instructions say just pull the black bezel, then loosen a nut, and pull the antenna mast.
I haven't been working on the underside of the car, it seems that's the way to go?
I'll get pictures this weekend.
Posted on: 2010/3/26 13:26
nope, from the topside.
that's the way to do this...
Posted on: 2010/3/26 18:14
1389 Posts
Here's the picture, from the topside, that black thing, how do I get it off?
Posted on: 2010/3/28 21:50
Matatk Re: Antenna mast on an 87
If it's the same as my 89, it's a rubber piece that is just compressed in there. It has a line-up tab on the underneath side. Should be able to gently pry it out.
Posted on: 2010/3/28 21:54
1389 Posts
A screwdriver? I had a hook and was pulling on it, straight up, and the whole car was coming up, but the black thing didn't give. I was kind of afraid to really yank on it.
Posted on: 2010/3/28 21:58
Weird, I can almost remove mine with my fingers. It's pliable rubber. I was gonna say pry up with something plastic but sturdy. If you're gonna pry I'd definitely tape it off and use some towels around the area just in case.
Posted on: 2010/3/28 22:05
1389 Posts
Mine isn't any kind of soft rubber. It feels more like the stuff the seat backs are made of.
Posted on: 2010/3/28 22:07
Dale, it is hard to tell from the picture, other than that you are working at the right spot. Will the mast nut socket fit inside the bezel and contact the mast nut? That is what needs to happen.
Posted on: 2010/3/28 22:50
1389 Posts
No. The opening is only big enough for the antenna mast itself to fit though. I think Matt is right, the black thing has to come out, but it's not soft rubber. It's pretty rigid, and doesn't give.
Posted on: 2010/3/29 3:26
rayquayle Re: Antenna mast on an 87
139 Posts
On the early C4s ('84-'87) the mast is not replaceable from the top as it is on the later ('88-'96) cars. The black bezel will not pop or pry out on these early cars. It is held in by threads and the bezel nut below the body panel. Dale, you'll have to remove the antenna assembly to replace your mast. Easiest method is to jack up driver side rear, remove wheel and inner fender. Should then be able to remove antenna and replace the mast on the bench.
Posted on: 2010/3/29 10:37
Ray Quayle in England
'86 Indy PaceCar, 4+3
NCM Founder #2896
NCM Lifetime #672
Graduate of Gordon's School
Ray to the rescue! I'm glad someone has experience with an earlier one. That should get Dale on the right track. Now about those banksi pieces....
Posted on: 2010/3/29 11:34
1389 Posts
Thanks Ray!
Posted on: 2010/3/29 13:45
Dale, sorry I was giving you some bad info. I even did a 'google' on changing an 87 mast and what I found was obviously wrong as well. Glad Ray was able to provide the correct way to fix it.
Posted on: 2010/3/29 18:59
1389 Posts
No problem. You were trying to help, I appreciate it.
Posted on: 2010/3/29 19:07
