Matatk | What thread sealant? | ||
This is a little premature since it's not assembly time yet, but on the manifold air temp sensor there is a red sealant on the threads. What is that?
Matthew |
Posted on: 2010/4/22 23:33
BillH | Re: What thread sealant? | ||
Same kind the factory applies on the OEM sensors. Not sure exactly what it is but it works both mechanically and electrically if needed.
Posted on: 2010/4/23 0:36
mseven | Re: What thread sealant? | ||
I remove that stuff as I have had problems with the lock-tite stuff that comes on factory replacement sensors (used in on an aluminum intake some time ago and when I removed the sensor it tried to take some of threads with it). I use liquid Teflon or the tape and haven't had any electrical or sensor issues.
Posted on: 2010/4/23 1:44
Matatk | Re: What thread sealant? | ||
Thanks, Mick. I was planning on using teflon tape since that's what I have laying around, but I would buy the red stuff if it's necessary.
Matthew |
Posted on: 2010/4/23 1:47
SpectatorRacing | Re: What thread sealant? | ||
I like the ARP thread sealer. I use it instead of teflon tape nowadays.
Posted on: 2010/4/24 23:23
aka Scaryfast |
This one? http://www.summitracing.com/parts/ARP-100-9904/ Is $9 the going price? I'm sure a tube would last me about forever. I have plumbing pipe dope, but I doubt that's 500* rated like the ARP (not that an intake plenum gets that hot, but still). Can you use the ARP sealant for other bolts, such as thermostat housings, etc? Matthew |
Posted on: 2010/4/25 11:47
Yes and Yes |
Posted on: 2010/4/25 14:55
Josh | Re: What thread sealant? | ||
The red stuff on the threads is an anti-galling compound, not a thread sealant.
The directions that come with the sensor will tell you that you need to use a thread sealant of some kind because the manufacturer did not install thread sealant, only anti-galling compound. |
Posted on: 2010/4/25 15:29
