111 user(s) are online (68 user(s) are browsing Forums)
Weavsvet Heads going back on
446 Posts
Posted on: 2010/6/4 23:17
Aboatguy Re: Heads going back on
My Avatar was redistributed!
498 Posts
Looks good ....got it running Yet?
Posted on: 2010/6/5 0:41
BrianCunningham Re: Heads going back on
saw it over on CF
looks great
Posted on: 2010/6/5 1:08
Matatk Re: Heads going back on
Looks good. Glad your edelbrock casting was better than mine
Posted on: 2010/6/5 2:22
vis_croceus Re: Heads going back on
VA
260 Posts
How much did the NAPA washers cost? napaonline won't give me a price.
Got some today at Autozone for $3/ea
Which is still way cheaper than GM...
Posted on: 2010/6/5 4:39
94 vert
Weavsvet Re: Heads going back on
446 Posts
It was about $5.00 for all four. I looked at Autozone but came up empty. That is why I ended up at NAPA.
Posted on: 2010/6/5 5:09
446 Posts
Does it look any better to you in the pictures? I had heard it wasn't very good but thought I'd have a look see for myself. My experience is not very good at this so maybe I'm missing something. Are you speaking of the ports themselves or it the bolting up to the heads or what? I can probably touch the ports up if you think they aren't good enough as is.
Posted on: 2010/6/5 5:16
446 Posts
Not yet but it should be running later on today, hopefully.
Posted on: 2010/6/5 5:20
My intake had a lot of little casting/machining flaws. Stuff like extra material inside EGR ports, big ugly casting ridges in the ports themselves, some of the threaded holes were crappy and I had to chase them. Just from the pics I saw, yours looked better than mine. Obviously I can't inspect yours up close, but just my general observation. This is also comparing my hi-flow intake base to your LT4, but it speaks to Edelbrock's general mass production vs quality.
Posted on: 2010/6/5 11:44
446 Posts
They must have got their act together. Below is a picture of the only issue I had. The heads have a lip on them the intake wouldn't quite go by so I had to grind a little bit off each side.
[IMG]http://i274.photobucket.com/albums/jj256/WEVSVET/AFR%20195%20heads%20going%20back%20on/IMG_3276.jpg[/IMG]
[IMG]http://i274.photobucket.com/albums/jj256/WEVSVET/AFR%20195%20heads%20going%20back%20on/IMG_3277.jpg[/IMG]
Not finished yet. Hopefully tomorrow.
Posted on: 2010/6/5 21:30
446 Posts
It runs......
http://s274.photobucket.com/albums/jj ... view¤t=MVI_3287.flv
[IMG]http://i274.photobucket.com/albums/jj256/WEVSVET/AFR%20195%20heads%20going%20back%20on/IMG_3289.jpg[/IMG]
[IMG]http://i274.photobucket.com/albums/jj256/WEVSVET/AFR%20195%20heads%20going%20back%20on/IMG_3290.jpg[/IMG]
[IMG]http://i274.photobucket.com/albums/jj256/WEVSVET/AFR%20195%20heads%20going%20back%20on/IMG_3291.jpg[/IMG]
[IMG]http://i274.photobucket.com/albums/jj256/WEVSVET/AFR%20195%20heads%20going%20back%20on/IMG_3288.jpg[/IMG]
Posted on: 2010/6/7 0:10
biggrizzly Re: Heads going back on
Mike,
Its looking hot! I love the valve covers, what do you think of them? Not too bad a price for custom covers either.
Posted on: 2010/6/7 2:08
pianoguy Re: Heads going back on
Sweet!
Posted on: 2010/6/7 2:15
When are we going to the dyno? race track?
Posted on: 2010/6/7 2:27
446 Posts
biggrizzly wrote:
Mike,
Thanks Grizz!
Quality wise, excellent. Fitment wise, they have problems.
passengers side needed a hole for the vent tube on my '96. No problem there just popped a 7/8 hole in and put the grommet in.
Drivers side is not so good. Had to grind a little here and there to get it to fit because of the wiper motor and the AC/alternator bracket. This was mentioned to me but of course being me I continued on anyway. Once on, the alternator won't go down far enough for the top bracket hole to line up. It hits the cover on the bottom. I did use a cork reinforced gasket and they are a good 3/8" or better thick. So that is probably part of it.
Having said all of this I'll come up with something to make them work. I like the look of them and can't see going back to the OE covers.
Posted on: 2010/6/7 5:42
446 Posts
We hope to go to one or the other if not both this coming weekend the 11th & 12th.
Posted on: 2010/6/7 5:44
tpi421vett Re: Heads going back on
Salt Lake City Utah
125 Posts
Looks awesome Mike. Nice job!
Posted on: 2010/6/10 3:42
08 C6 LS3,3LT,Z51,A6,NPP
450ci now with AFR 235...
congrats!
Posted on: 2010/6/10 17:45
