282 user(s) are online (213 user(s) are browsing Forums)
Also known as NHMS....
Weavsvet I need more air...........
446 Posts
At least my tuner says I do. I finally got a WOT data log to him. I'm runninga OE intake with a cut lid and a K&N. Here's what he had to say........
Two things I noticed are that your airflow reading is not very high considering your mods. I would think it should be a good bit over 300 gm/s, but yours is just barely breaking that. The other thing is that your MAP reading is not staying close to 100 KPa at WOT, which usually indicates an airflow restriction or valve float could be related to the low airflow reading).I would check out that in the meantime.
As far as the valve float I upgraded the springs on the AFR's to the next size springs(8019 I believe). I knew I was close to their standard springs with the lift I have plus the 1.6 rockers. Thoughts?
Posted on: 2010/6/24 19:21
BrianCunningham Re: I need more air...........
next time you dyno, yank the filter all together and see what happens.
Did you descreen the MAF?
It's really there to straighten the flow on F-body cars, which have a 90 bend in their air track
sounds kinda silly, but did you check and make sure the throttle blades are openning all the way?
don't laugh, it's happened.
what are the specs on the springs?
Seat pressure etc.
Posted on: 2010/6/24 19:35
Weavsvet Re: I need more air...........
446 Posts
Thanks Brian I'll try that.
MAF is stock, not descreened
AFR-8019
1.270 OD Size
155# @1.810 Pressure
1.080 coil bind
428 Rate
650 Max lift
Premium Grade
Posted on: 2010/6/24 19:41
446 Posts
I shouldn't need a 58mm tb with a stock bottom end should I?
Posted on: 2010/6/24 19:50
rklessdriver Re: I need more air...........
I don't think the air filter assy or MAF are an air flow problem right now. I know a couple of cars that are making more power with the same set up. Don't get me wrong, it's a restriction - as any plumbing infront of the TB is going be after a certain distance but plenty of folks are still running the stock stuff and making more power so I'd look else where.
I also don't think you have to have a 58mm TB at this point. However TB's are pretty cheap and really easy to change. If you want to try a 58mm TB, PM me and I'll loan you one I have sitting around.
Posted on: 2010/6/24 20:27
446 Posts
I looked at the file and at WOT the lowest MAP was 94kpa.The highest was 98kpa. Max rpm was 6300.
I'm going to make another run with the air filter removed and see if the KPa goes up any.
That's mighty generous of you Will! I may take you on it if I can't find anything else that's wrong. That way I'd know anyway without guessing. Thanks
Posted on: 2010/6/24 21:10
careful on the RPM with the stock bottom end
your already over what I'd rev it to.
Posted on: 2010/6/24 21:28
446 Posts
yeah I know. I was surprised to see it went that high. I had him set the rev limiter at 6200 in the other tune. He may have forgotten to set it back in this tune. I'll keep an eye on it.
Posted on: 2010/6/24 21:37
446 Posts
Maybe the ole Edelbrock air gap is flowing better than it's reputation gives it credit for.......
Posted on: 2010/6/24 21:52
but you NOT flowing enough air???
Posted on: 2010/6/24 22:31
from "over there"
[QUOTE]Weav's Vet;
Could it something on the other end, the exhaust? I had the cutouts closed when I made this WOT run. How about cats? Partially plugged maybe? Headers 1 5/8, maybe 1 3/4 would be better. I mean the air has to get out as fast as it's coming in, right?[/QUOTE]
could be the cats
how old are they
what did you install? (I see longtubes in you sig)
Posted on: 2010/6/25 0:41
dan0617 Re: I need more air...........
Mine's an '89 so my setup is a little different, but my MAF will only read up to 254 gms/sec.
Also, I'm running all the stock stuff in front of the throttle body, except for a cut lid and K+N filter. I put on a stock tb bored out to 52mm and noticed no difference over the stock 48mm tb.
Posted on: 2010/6/25 4:10
446 Posts
from "over there"
[QUOTE]Weav's Vet;
could be the cats
how old are they
They are high flow bullet type and came with the Stainless Works headers. I guess about a year and a half old. maybe two. When I re installed the OE exhaust system I had them off. I could see through the honey comb inside if I held them up to a light. If I shook them they rattled like the honey comb inside was loose. Is that normal? One of them and I don't remember which looked like it had gotten really hot at some point. The outside casing had a bluish tint to it. All of this was before the head swap. About 3-4 months ago.
Down at the track last year in one of my moments of total stupidity I ran about 3 gallons of 112 octane through them. I was lower on gas than I had thought so I got that to make my runs and make sure I made it home. I guess there might have been 3 gals or less in the tank of 93 octane so it was a 50/50 mix more or less. I ended up replacing the O2's because of the lead and after that and it seemed to run ok so I didn't really question the cats anymore. (Lesson learned!) Now I am though since they are being put to the test here with exhaust flow.
Posted on: 2010/6/25 5:36
446 Posts
Seat pressure etc.
When I re installed the OE exhaust system I actually did pull the filter out. I went to the dyno with a stock filter in there and wanted to see if I could get anymore with it removed. I did, it made 6 more rwhp on the next pull. Not much but I'll take it all!
So even if the TPS says the throttle is wide open the blades might not be, interesting? I'll have to check that. Thanks!
Posted on: 2010/6/25 5:42
Josh Re: I need more air...........
Doesn't the MAF max out in the tune at 255 GPS? I thought that was the limitation of the hex code used to write the software.
I would take the MAP sensor off and look at the hole it, see if there is some crap or something in there. Also, what does the data logger show the MAP reading is when the car is not running? If you aren't seeing 100 KPA there, the MAP sensor is probably bad.
That is where I would start. I don't think you'll see more than 255 out of the MAF sensor, and I think there is something wrong with the MAP sensor. I can't imagine that you'd be seeing enough of a restriction via intake tract to significantly decrease the power.
Posted on: 2010/6/25 16:41
98 KPA is within reason for WOT. I don't think I see 100 in my car every time I floor it. Most of the tables in the tune go from 95-100 KPA, so at 98 you are using the WOT settings.
What is the elevation where you are? When I lived at elevation (4500 ft) the KPA readings on the car got a little whacky.
Posted on: 2010/6/25 16:45
446 Posts
KPA is 100 with the ignition on and not running. Nothing blocking the hole of the MAP. However, the gasket could be in better shape. The ribs are intact but the part next to the sensor is kind of ragged looking.
Elevation here is in the 400 ft range
Posted on: 2010/6/25 18:21
Have you looked at the datalog yourself? What MAF gms are showing? I don't think 94 MAP is very far off. Easily could be TB blades not fully tightly open. Carpeted floormat can cause that, I had that problem once. Might just need to adjust the throttle cable bracket a hair.
Maybe you could attach your datalog for a few of us to look at, or export it to a CSV file and open it with microsoft excel and look at it that way. I'm just not so sure you have a problem at all.
Posted on: 2010/6/25 20:33
446 Posts
Thanks Dan, yes I looked at it. I also checked the tb blades. They look completely flat to me at WOT. I'll see what I can do about the CSV file.
Posted on: 2010/6/25 20:41
446 Posts
Here it tis..........
csv wot 2 data log excel.csv Size: 46.41 KB; Hits: 135
Posted on: 2010/6/25 21:12
Aboatguy Re: I need more air...........
My Avatar was redistributed!
498 Posts
Looks like in only hit 300+ in one cell....seems like most of the high flow was 280ish ....so looking at the AFGS readings I have to agree with your tuner something is amiss ...unless you didn't have the heavy air (..using your words) or your heads/intake...etc are not flowing what you think... do you have the approximate DA from datalog time, are your intake manifold lined up with the intake ports, are the headers/gaskets...lined up with the exhaust ports.....
Posted on: 2010/6/25 22:52
498 Posts
I don't know what the max is for the LTX MAFs but I have plenty of 370+ AFGS readings on the datalogs for my 95 LT1....
Posted on: 2010/6/25 22:53
446 Posts
Density Altitude: 1430 feet
Relative Density: 95.88 %
The intake ports looked pretty good to me. The exhaust ...as you know the SW headers are 1 5/8 D ports so there is a slight mismatch there. I was told by someone at AFR a while back that they would be fine though. What else could I go by........
Posted on: 2010/6/25 22:59
498 Posts
The intake ports looked pretty good to me. The exhaust ...as you know the SW headers are D port so there is a slight mismatch there. I was told by someone at AFR a while back that they would be fine though. What else could I go by........
I guess the easy stuff...remove aircleaner from front of maf....
However, my cut airlid and filter will flow more than 370 AFGS
JMHO..
[IMG]http://i14.photobucket.com/albums/a342/aboatguy/6900.jpg[/IMG]
Posted on: 2010/6/25 23:22
Steve40th Re: I need more air...........
1114 Posts
Back in post 13 you said your catalytic converter rattled? That is not good, it is broke if it is rattling. I would definitely look at it with the exhaust open so you can see if it is clogged/busted etc.
Posted on: 2010/6/26 1:56
Ko'u ohana aia ku'a ikaika
446 Posts
Not busted Steve but it sounds like the whole insides is just moving around in there in one big chunk.
Posted on: 2010/6/26 2:01
1114 Posts
A busted catalytic converter can cause problems with Knock Sensors, and can be a flow restriction. If it is feasible, I would look into them to see if it is broke.
My 93 broke one at rockingham and it ran rich. I have a VHS tape from years ago where my we saw the difference at Rockingham when it broke.
Posted on: 2010/6/26 5:58
446 Posts
Ah, a new twist....interesting. This is a new data logging program I have and one of the most valuable PID's is not there for some reason. Knock retard. The company I got it from is supposedly writing me another download file that has it included. I'll most likely wait and see how that comes out before running out and buying new cats. What you're saying makes sense though Steve. Even before this head swap this car was always been sluggish on the top end. Maybe this is the reason why. Thanks!!!
The good ole days.......In the mean time can you play that VHS tape for me?
How's your car running? Did you get the tune squared away?
Posted on: 2010/6/26 6:17
1114 Posts
I am in San Diego for two more weeks. My transmission valve body is sitting on the shelf from Dana, he fixed some extra holes that were drilled etc. And my new 42# injectors are awaiting install. The 36#'s had one leaker.
So, my tuner as you know will work with me when I get back. My tune was pretty good to begin with with the 30#'s, hopefully the 42's will be easy to adjust too.
Once I get this stuff done I am going to dyno it. I am looking at 420-430 ish SAE.
Posted on: 2010/6/26 6:21
446 Posts
Here are the pictures of the gasket I used on the heads and the intake. I don't have a picture of the exhaust gasketI used. Like I said earlier it's a D port gasket so it can only be so good.
I'm going to pursue what Steve has mentioned about the cats. It just has to be something more than a air intake restriction I can't find.
Photobucket
Photobucket
Posted on: 2010/6/26 11:35
I probably missed it, but what kind of power did it make? I assume the tuner discovered these issues on the dyno, right?
Posted on: 2010/6/26 14:51
446 Posts
well.....when I had it on the dyno it made 376/328 std. That was with another tune on a very hot and humid Sat. morning. This data log wasn't exactly done on a dyno......
Posted on: 2010/6/26 14:54
446 Posts
I made another data log this morning. Air filter was removed, a different MAF sensor, and a smooth intake tube between the tb and the MAF sensor. Looks like it improved a little. I still believe it's pulling timing with those cats rattling around inside.
csv wot 3 csv.csv Size: 41.22 KB; Hits: 114
Posted on: 2010/6/26 14:57
446 Posts
I have another one of crazy questions. I just have to cover all the bases.
I had my tuner remove the EGR in the tune but I left the valve on the intake manifold. This couldn't be having any affect on what is going on with all this MAP pressure business could it? I know the gasket is good and it is tight on the intake and the vacuum line is still connected.
Posted on: 2010/6/27 9:03
498 Posts
I'd be more concerned with the fact that the headers/gaskets...blocking part of the exhaust ports..
I posted this on the other site...
AFAWIK blocking part of the exhaust port is going to hurt your performance... IMO time for headers that fit ....IE header opening are same size or larger than exhuast port...
I had header gasket issue when I changed to the AI 200s my Percy's gaskets were blocking the port a little.....
Finding the right gasket helped end the soft upper end....
IMO if your heads are as good as claimed and you are using the 280XFI your engine should pull up to your redline...(ie whatever rpm you feel safe running factory shortblock to)
However, lousy exhaust doesn't explain a high map to baro pressure delta..(if in fact you have a high delta)
I remember reading (shortly after the edelbrock manifolds release) that the Edelbrock LT1/4 airgap manifold had a decreased plenum volume....I wonder if the decreased plenum volume has anything to do with your map/baro delta...
Posted on: 2010/6/27 14:35
446 Posts
AFAWIK blocking part of the exhaust port is going to hurt your performance... IMO time for headers that fit ....IE header opening are same size or larger than exhaust port...
I've asked this question before and the answer usually was I don't need different headers. But I also included the phrase "should I get 1 3/4 instead of 1 5/8 like I have now"". But getting 1 5/8 headers to match up with the size of the AFR port may be difficult. To me it would seem having the exhaust port match the header would be just as important as the intake matching the head. But what do I know.........
I also asked the question about the intake being the problem and the answer was that it was not because of one of these pressure readings. I'd have to go back and find which one though. I may be mistaken but I swear I read on AFR's website that they recommend the LT4 Air Gap as the preferred intake with these heads I have.
Posted on: 2010/6/27 14:50
1114 Posts
I took my 1 3/4 headers and port matched them to my exhaust pots on my CNC heads so they would have no restriction. Mine are DRM stainless, so they are strong and a little grinding didnt hurt.
Mike, take a breather and do one thing at a time. That way you are sure whatever you did was correcting the problem.
Posted on: 2010/6/27 15:57
446 Posts
Thanks Steve
But you've got that big ole 396 in there.
Yeah I'm bad about jumping around I guess. Not productive probably. Having said that........
I reinstalled the OE MAP sensor and made another very short log. K&N in place and aftermarket MAF in place. It changed the readings a little. I wonder if I should put the OE MAF back on if it would change even more.
csv wot 5 CSV.csv Size: 18.64 KB; Hits: 98
Posted on: 2010/6/27 16:06
1114 Posts
as long as you are logging things to know what you have done.
396 needed the larger headers, but your heads are much better flowing than mine, and that is where most of the HP is.
Posted on: 2010/6/27 16:10
1114 Posts
Do you have pictures of your header gaskets up against the heads?
Posted on: 2010/6/27 16:11
446 Posts
Sorry Steve that is one thing I did not take a picture of.
Posted on: 2010/6/27 17:42
498 Posts
OK in simple boatguy terms.....
I've always been told (by folks I trust) that its better for the exhaust flange (opening) to be bigger than the exhaust port ...so that the (lip) acts as an antireversion step.....same principal as anti-reversion stepped headers... whereas when you block some of the post your bouncing exhaust back into the post and if your a port matched you lose the step from exhaust port into the larger header opening losing the antireversion effect....
But once again this will not cause your MAP pressure delta
Posted on: 2010/6/27 18:19
446 Posts
You guys have got to listen to this. Is this normal?
I installed a PP 58mm tb on the car this morning. All in all idle is better or at least smoother. Throttle response is really nice but...........it sounds like a damn vacuum cleaner in the front of the car......at idle!
Posted on: 2010/7/2 15:55
498 Posts
Doesn't sound like my old BBK...
However, take it out for a drive with the datalogger running and see whats up... You may have to set the throttle blades IOT get the proper IAC count...
Posted on: 2010/7/2 16:54
1114 Posts
Mine has a slight whistle to it due to me drilling a hole through the center for the idle circuitry.
This thread shows the hole needed to assist in idle on a couple tbodies. I have the AS&M version.
http://www.ls1tech.com/forums/lt1-lt4 ... arizona-speed-marine.html
Posted on: 2010/7/2 17:33
446 Posts
I did this on my 52 but it still idles like crap. I used something similar to this. I believe it was in a tips section on the Grand Sport website written by Jim Mason. This site is about the same..
http://members.cox.net/chipsbyal/page/idle/index.html
Posted on: 2010/7/2 17:41
flyboy Re: I need more air...........
IAC valve or throttle blade setting? Mine had the same sound this winter when I was messing with the idle after my cam change and my memory is failing.
Posted on: 2010/7/2 17:43
My 92 sounded the same way at the air cleaner when I had the 58mm on there. You should hear it now with the AS&M Mono Blade....
Posted on: 2010/7/2 19:15
Mine sounds the same way, it is loudest when the car is cold/warming up.
Posted on: 2010/7/2 19:31
498 Posts
How do you like the monoblade????
Did you gain anything over the 58MM?
Posted on: 2010/7/2 19:47
