269 user(s) are online (210 user(s) are browsing Forums)
Weavsvet Idle rpm vs in gear idle rpm
446 Posts
On a '96 LT1 A4 what controls this?
IOW, when I put the put the car in gear the idle does not seem to compensate for it being in gear. Is this something that is controlled in the PCM or is it handled by the IAC or what exactly? Thanks
Posted on: 2010/7/1 11:22
flyboy Re: Idle rpm vs in gear idle rpm
The IAC motor is controlled by the ECM according to engine load and temp. My '91 would die when cold when put into gear and almost die when warm with my mail order chip. Now that the car has been tuned on site by an expert (not me) the transition is seamless.
Posted on: 2010/7/1 12:51
Steve40th Re: Idle rpm vs in gear idle rpm
1114 Posts
The ECM does tell the engine what rpm to idle at in gear, with and without AC too, as you can add rpm for ac.
What is it doing exactly?
Posted on: 2010/7/1 13:33
Ko'u ohana aia ku'a ikaika
vetteoz Re: Idle rpm vs in gear idle rpm
There is a switch on the auto shifter that tells the PCM if car is in N/P.
Posted on: 2010/7/1 14:19
1114 Posts
I know within the transmission there is a switch that tells the ecm what gear it is in so the ecm will compensate. At least on my 93. Ask me how I know
Posted on: 2010/7/1 14:46
Woodstock Re: Idle rpm vs in gear idle rpm
Bremen/Germany
369 Posts
96 is always a tough case, but the earlier OBD1 softwares were giving you a desired idle speed and an actual engine speed, according to set ECM parameters.
Throttle body opening and IAC play the main role in control.
@flyboy
Do you got a copy of the bin prior to the correction and now?
I am fighting with this problem on a friends 87 with stock torque converter, though. He's got an LT4 hotcam in his 383 stroked L98.
We are to a point where idle quality suffers by trying to correct this issue. A copy of the bin would be a big help. I might find similar values in the $6E hack.
Posted on: 2010/7/1 15:51
91 convertible
@flyboy
Sorry, no. The guy I paid to tune the computer did all that data stuff. It's greek to me.
Posted on: 2010/7/1 17:25
Weavsvet Re: Idle rpm vs in gear idle rpm
446 Posts
Ok, this sounds like my problem because when I turn the AC on it wants to die or search for it's idle also. It never seems to recover from the AC until the compressor cuts out.
When I put it in gear with my foot on the brake it's the same thing, it never recovers it's idle.
I was hoping there was a switch bad or something but I guess that's not the case. It sounds like a tuning issue.
Posted on: 2010/7/1 17:48
446 Posts
I did mention this to my tuner and he said he added 50 rpm to the in gear setting in the PCM but it ain't getting it. Just a pain to throw it in neutral at every stoplight.
Posted on: 2010/7/1 18:20
446 Posts
Went to town a little while ago and paid attention this this idle issue. Seems it gets a lot better when the water temp gets to 170 or above. Still not the greatest idle but much improved over a cold start. By the time the temp gets to 190 it's even better but still not as good as it should be. You guys with a 111 lsa or in the range anyway,what is your normal idle at? He has mine at 850 I believe.
Posted on: 2010/7/1 20:33
1114 Posts
I hate to say it, but your idle problems are identical to ou mine when the IAC went out. You have a new one correct from early in your troubleshooting. The ECM only tells you what it wants the IAC to do, you will never know what it is doing. only what is being commanded.
Take IAC out, measure to ensure it is at the right setting as if it was a new install, then put it in, but dont connect it. Start car and see what happens. I bet the IAC is dead.
Posted on: 2010/7/1 21:19
446 Posts
Ok, I'll see what happens. Thanks!
Posted on: 2010/7/1 21:37
1114 Posts
I have had a IAC that OHM'd good, and it was bad as the pintle was moved around by me. Not good so I must have broken the plastic gears. I am not sure how the 96 style IAC pintle is in there if it screws in or what, but, I think they are common across the board through GM. IE, if you have a 96 Camaro, Pontiac etc that has an IAC, I believe they are interchangeable to test them if yours OHMs good, but you may think it is bad.
Posted on: 2010/7/1 21:39
Aboatguy Re: Idle rpm vs in gear idle rpm
My Avatar was redistributed!
498 Posts
You may have to mechanically set your TB blade IOT get the IAC count low enough that it can compensate for the AC..
If you pull the IAC out of your TB and leave it plugged in and it moves when you turn the key on
its probably good....
(don't start it just turning the ignition on should make the IAC move "test")
....and setting the throttle blades correctly will probably fix your problem...
(It the throttle blades are too closed the IAC will not have enough range of motion left to keep the IDLE smooth in gear with the AC kicking... I know this from experience....)
Posted on: 2010/7/2 17:03
446 Posts
Aboatguy wrote:
I'm pretty sure the IAC is good. I can test it on the Tech1 I have. I've been playing with the blades readjusting the TPS voltage and then repeat that again. It's getting better every time.
Posted on: 2010/7/2 17:12
1114 Posts
On your car tps voltage resets every time you start.
The blades should be opened a little. I drilled the center out, as I posted on the other thread, and I put the throttle blade a 1/4 turn past touching.
http://www.ls1tech.com/forums/lt1-lt4 ... arizona-speed-marine.html
Posted on: 2010/7/2 17:41
Stl94LT1 Re: Idle rpm vs in gear idle rpm
128 Posts
There is a seperate tuning table for the IAC counts with the A/C on. The counts will be much higher.
Posted on: 2010/7/2 17:55
498 Posts
I agree....however , if the TB is closed too much the IAC will have to open more IOT idle and then it may be maxed out with out enough headroom to IDLE with the AC on...
Posted on: 2010/7/2 18:22
498 Posts
Weavsvet wrote:
Aboatguy wrote:
Steve's right the TPS will self adjust...and resetting the IAC is easy enough
Depress accelerator slightly
Start engine, then release accelerator pedal, run engine for 5 seconds
Turn ignition "OFF" for ten seconds
Restart engine and check for proper idle operation
(I try to get my counts between 30 and 40 at idle)
Posted on: 2010/7/2 18:26
