76Nordic | 1984 headliner question | ||
Dumbass
Just was wondering what any of you guys may have done for your headliner or not. Mine is completly gone, the only thing on the top is velcro strips. I have seen here and there, where the top was redone with the material and glue pretty cheaply, but they had a base to work with, so it seems.Thanks for any info you have Mark
Posted on: 2010/7/9 3:17
CentralCoaster | Re: 1984 headliner question | ||
Yeah, I still had the foam piece to use. It provides some insulation so the sun won't cook you as bad on a hot day.
With the stock foam, I peeled what was left of the stock fabric and matched it as close as I could at the fabric store. I gently brushed any loose stuff off the stock foam, used super duper 3M spray on adhesive, and then cut the edges with some extra, and tucked that in under the metal frame using an old credit card. I'd bet there's some 1/4 to 1/2" thick foam type stuff at the fabric store that you could bond black fabric over. Or get creative and use a different color that matches the interior... it's not like it will fade. There's also carpet padding, it would maintain it's thickness well, but it's heavier and may be harder to keep glued in... it works better as noise insulation than temperature insulation, so take your pick. |
Posted on: 2010/7/9 3:59
bogus | Re: 1984 headliner question | ||
it's not all that hard, really...
get a piece of cardboard, about the size of the headliner panel. 1/4" plywood is good, too. Cut the panel down about 1/8" along the panel edge, this will allow the fabric some wiggle room. Cover the panel. and then shove it up there on the velcro. |
Posted on: 2010/7/9 4:09
Matatk | Re: 1984 headliner question | ||
I'm not sure if cardboard will hold up. I would use cardboard for the original pattern, but then use a thin wood like luan for the base, cover it with foam (glued) and then the fabric you will use.
Matthew |
Posted on: 2010/7/9 12:20
Cardboard will look like hell. And the roof is curved anyways, so I'm not sure how a flat piece of anything would work well.
What's so hard about gluing carpet padding or foam directly to the roof? |
Posted on: 2010/7/9 17:13
I didn't know that's how they originally were. I was thinking it was more like a headliner in a car - ie, hardboard/foam/fabric. Since I have the acrylic top, I've never taken a painted one apart. Matthew |
Posted on: 2010/7/9 17:20
76Nordic | Re: 1984 headliner question | ||
Dumbass
Thanks for the replies! I will let you know how I do it, and how it comes out. Mark
Posted on: 2010/7/9 17:29
It's basically a semi-rigid foam piece shaped to the curve of the roof that has fabric glued to it. I've never had the foam out but apparently it attaches with velcro. |
Posted on: 2010/7/9 19:38
corvetteronw | Re: 1984 headliner question | ||
What about using some of that spray in bedliner stuff like they use in pickups? It comes in different colors and would never sag.
As far as fabric goes I have seen some pretty wild hot rod flame patterns that might look quite racy. |
Posted on: 2010/7/10 4:38
A VETERAN IS SOMEONE WHO AT ONE POINT WROTE A BLANK CHECK MADE PAYABLE TO THE UNITED STATES OF AMERICA FOR AN AMOUNT OF UP TO AND INCLUDING THEIR LIFE. |
85L98-84L83 | Re: 1984 headliner question | ||
I saw a guy on that british show "wheeler dealers" use some stereo carpet stuff in black and he used that spray on glue and glued it to the hard top. Great TV show by the way.
Posted on: 2010/7/18 15:15
85 vette - 3.54 gears,pulleys,160 stat,hypertech chip,K&N,no cat,B&B cat back,cut air lid,TB bypass,air pump elim pulley,air foil,Torque thrust II wheels,maaco paint job 84 vette - K&N,renegade,2 inch TB's,adustable fuel pressure to 15 psi,air pump e... |
polish41 | Re: 1984 headliner question | ||
I bought a piece of 1/2" styrofoam insulation at home depot. Cut it to fit the roof. Glued some new headliner material to it and stuck it on with some new velcro strips. That was three years ago and all is well.
Posted on: 2010/7/19 1:50
If your not living life on the edge your taking up to much space. |
Dumbass
Update.... I ended up finding one at corvette central, and after thinking about it a bit, I ended up buying it. Cost me around 140.00 bucks. But what I got I thought was pretty cool. It was a hard plastic, that was molded to the shape of the top, and cut perfectly to fit snug, and covered with the material. Hell it even had the velcro strips on the back. So in the future, I guess I have the foundation to work with if I need to replace the material. Thanks guys for all your suggestions !!!!!!!!
Posted on: 2010/10/15 1:06
