djxib | Tapping noise above 2000 RPM part two | ||
(from previous thread). 1992 383 LT1 / LT4 heads + Vortech
I got fed up not being able to work out where the tapping noise is coming from. So I removed the supercharger belt and now I can clearly hear the tapping at idle. The tapping gets much worse and very loud above 2000 RPM. I pulled both valve covers and it seems to be more pronounced at #8 exhaust. I re-set the lash and made no difference - still taps like a mofo. To be honest the tapping seems centered at the rear of the intake. So I threw half a can of seafoam in the crankcase and ran the car for 10 minutes and I am leaving overnight. If it is gone then I had an sticky lifter (which I actually dont hold out much hope for). If it is still tapping, I will remove the intake and throw a new set of lifters in there plus inspect everything. If it is a lifter it is weird because I put the current set of LS7 lifters (according to SDP they are compatible) about 10,000 miles ago. Guru comments welcome... |
Posted on: 2010/7/13 1:41
Andy 1996 Greenwood Collectors Edition LT4 Previously 1992 Convertible Polo Green. 383 LT1/LT4 forged/balanced. V7-YSi, Alky. 608RWHP... Now sitting at a dismantler with a salvage title. Still runs... |
Matatk | Re: Tapping noise above 2000 RPM part two | ||
I would suspect a lifter, myself, or a noisy rocker. Are your rocker arms in good condition? What about the pushrod - not bent or damaged?
LS7 lifters should be fine AFAIK. Matthew |
Posted on: 2010/7/13 1:52
BillH | Re: Tapping noise above 2000 RPM part two | ||
Have you tried stickin' a screwdriver in your ear and putting on top of both #8 rocker arm studs?
Posted on: 2010/7/13 1:55
bogus | Re: Tapping noise above 2000 RPM part two | ||
what Bill said.
Posted on: 2010/7/13 2:00
Livin_the_dream | Re: Tapping noise above 2000 RPM part two | ||
x2 located many of noises that way! |
Posted on: 2010/7/13 2:05
pianoguy | Re: Tapping noise above 2000 RPM part two | ||
Let's hope it isn't a spun bearing.
Posted on: 2010/7/13 2:45
dan0617 | Re: Tapping noise above 2000 RPM part two | ||
Bent or burnt exhaust valve?
Posted on: 2010/7/13 10:57
djxib | Re: Tapping noise above 2000 RPM part two | ||
Yep - used a mechanics stethoscope to home in on #8 exhaust. But to the "naked ear" the noise is coming from the intake. Will post results later....
Posted on: 2010/7/13 11:37
