229 user(s) are online (197 user(s) are browsing Forums)
tjpreul wanted: lt1 heads for cheap
I am looking for a set of LT1 heads for cheap. I am going to put them on the shortblock I have, and install it while I rebuild the factory motor. My motor is fine, but its going to take a while due to expense restrictions. This is why I would rather run the shortblock that is in almost new condition.
Posted on: 2010/9/2 2:25
bogus Re: wanted: lt1 heads for cheap
reach out to cuisinartvette. He had some.
Posted on: 2010/9/2 6:43
demco307 Re: wanted: lt1 heads for cheap
Louisiana
50 Posts
I havent started on my engine yet,probally going to take it out at the end of october or first of november depending on how soon I recieve my afr heads but when I do your welcome to both heads,Im not planning on using them. there stock but are in use on my car as we speak.Freeee ought to be a good price. Darren
Posted on: 2010/9/19 2:04
cuisinartvette Re: wanted: lt1 heads for cheap
unfortunately I sold all the heads on ebay awhile back too much stuff laying around.
Posted on: 2010/9/19 4:57
Durango_Boy Re: wanted: lt1 heads for cheap
Tyler I have a set of LT1 heads but they are iron. I assume you want aluminum?
Posted on: 2010/9/19 12:20
tjpreul Re: wanted: lt1 heads for cheap
I want to stick to the stock look. Plus I read an article about saving weight recently!
Posted on: 2010/9/20 13:27
jaa1992 Re: wanted: lt1 heads for cheap
Stone Mtn, GA (near Atlanta)
187 Posts
I'll have to look at the heads I have in the shed.
What are you looking to pay with shipping?
You will want to clean them up and maybe put new seals and springs. IIRC the machine shop charged me a little over $200 to clean a set of heads, change the seals and put on new springs that I provided.
I know I have two sets in there, but one set I'm going to use on my engine build. I'll have to dig them out and take pictures of the extra set. IIRC they are 100K mile stock heads
Posted on: 2010/10/7 23:00
Thanks for the replies. My plans changed. I am rebuilding the shortblock instead of the factory motor. This way I won't have to switch the motor twice, and I was able to have the 2-bolt converted and prepped at a decent price.
Posted on: 2010/10/11 17:53
JeffK Re: wanted: lt1 heads for cheap
High Point, NC
1440 Posts
What is the difference between the LT1 heads and L98's?
I think I have a head gasket leaking and would rather get heads before and have them prepped for less downtime.
Posted on: 2010/11/10 2:40
The LT1 cooling ports are different, because they are a reverse cooling.
Posted on: 2010/11/10 2:55
High Point, NC
1440 Posts
Ah! Thanks for that information
Posted on: 2010/11/15 21:32
