150 user(s) are online (102 user(s) are browsing Forums)
Transverse Leaf Spring
BrianCunningham Range Rover as a tow vehicle?
Been searching for a tow vehicle to haul my Corvette to the track.
Open trailer 2000lbs, electric brakes on both axles.
I've been checking out 1/2 ton pickups,
but someone at my new contract is selling and old, 87, Range Rover looks to be a nice truck and I've always like them.
He's asking $7500 for it, 80k on the odo.
Kind wonder if that old Buick V8 has the suds to pull it though.
Anything else I should look out for?
Posted on: 2008/1/16 23:59
bogus RE:Range Rover as a tow vehicle?
I would avoid it like the plague.
They are electricially questionable, and the 215 is weak.
If it was me, I would look for something like what CentralCoaster has.
Posted on: 2008/1/17 2:40
jsup RE:Range Rover as a tow vehicle?
1778 Posts
They have rear end problems from towing.
Cite: Close personal friend who is, well, a Range Rover Mechanic.
Posted on: 2008/1/17 2:47
94z07 RE:Range Rover as a tow vehicle?
94 Posts
I bet you could find a road master wagon 1996 for a song. You already know the LT1 too.
Posted on: 2008/1/17 12:10
redwing76 RE:Range Rover as a tow vehicle?
25 Posts
Ya know I think the Rover would be a fine tow vechicle. I see them being towed all the time.....................
Posted on: 2008/1/17 18:51
Jeffvette RE:Range Rover as a tow vehicle?
Brian, pass on the Rover. They are garbage.
Find a 00 or newer silverado or sierra. 1500 series will be fine for what you are towing. Just get the 6.0 liter.
Posted on: 2008/1/17 21:11
BrianCunningham RE:Range Rover as a tow vehicle?
Well, you've definitely convinced me not to buy it,
not to meantion given me something to print out and give to the seller when he asks why .
The seller's daily driver is an Expedition, the Rover was his GF's.
He actually does a lot of towing himself.
I asked why he didn't get a 1 ton pickup.
He said the large SUV's were cheaper used,
and that the large Ford SUV's were cheaper than the Chevies.
Something for me to think about.
Posted on: 2008/1/19 21:07
red_johnny RE:Range Rover as a tow vehicle?
I towed stuff with my minivan all the way up to a camaro but never on a full trailer. I would go with a SUV but it all depends if thats the only thing your going to use it for.
Posted on: 2008/1/19 21:39
I'll also be using it to finish this off.
Hauling 4x8 sheets of ply in the back would be great, but I could always put it in the trailer.
The boat doesn't weight much, so that's not an issue. Taking it to out of the way put-ins would be cool.
Posted on: 2008/1/21 2:23
Steve85 RE:Range Rover as a tow vehicle?
Winchester, VA
28 Posts
A former Range Rover tech here that would prefer to tow with my 180K 2001 Silverado any day. They are nice inside and very capable off-road machines ut wayyy underpowered. The engine design, and I don't know how much they changed with the latest iteration, was a 60's Buick design used because it was all aluminum.
Posted on: 2008/1/21 2:44
1985 Silver, Richmond 6spd, 408cid
