171 user(s) are online (119 user(s) are browsing Forums)
1969 through 1976 Corvette.
pappyfreebird more questions
1028 Posts
just rememered...when drove to tech school i got on her a lil in 1st and 2and n hit 3rd but backed off gas and could feel shifter jumpin a lil...hadnt done it driving normal...and werent on it that hard but could feel it shake in my hand... worn fork? simply worn 3rd any idears?? last question think ill get away with just driving it being careful of hard decal. in 3rd ???
Posted on: 2008/1/18 1:24
CFI-EFI RE:more questions
Top of Utah
372 Posts
Unbelievable!!!
RACE ON!!!
Posted on: 2008/1/18 1:39
1Fast04Vert RE:more questions
Check the C beam, Motor and Trans mounts.
Notorious Re: more questions
Regardless of their condition. I don't believe any of your stickers could cause this problem.......
Posted on: 2008/1/18 3:33
bogus RE:more questions
I would say the C-beam bolts have come a bit loose.
Posted on: 2008/1/18 3:38
pappyfreebird RE:more questions
1028 Posts
thank you people...next question how the L do you git under these things all the time???? i have floor jacks etc but they dont git it non to high...wish i had a car lift ...bike lifts were best thing i ever bought fer shop
Posted on: 2008/1/18 15:56
Top of Utah
372 Posts
Check the Trans mounts.
use idnt figged howse ta git er ona bik lif yit??tork dem trans mts to 47nm
RACE ON!!!
Posted on: 2008/1/19 2:28
cuisinartvette Re: more questions
Posted on: 2008/1/19 4:09
rayquayle RE:more questions
139 Posts
RACE ON!!!
Now that I understood!
Posted on: 2008/1/19 10:50
Ray Quayle in England
'86 Indy PaceCar, 4+3
NCM Founder #2896
NCM Lifetime #672
Graduate of Gordon's School
CasetheCorvetteman RE:more questions
Series 4 Corvettes dont have trans mounts. They connect to the c-beam
Posted on: 2008/1/19 11:09
Top of Utah
372 Posts
Killjoy!!!
RACE ON!!!
Posted on: 2008/1/19 18:47
1028 Posts
again...cant check cause now cars in tech shop...but sure hope you cats is right...sure felt like that shifter were shakin in my hand (back n forth) like wantin to pop out a gear...would think (yes i do occansionally cf) loose c beam wood make it feel like raising up n down...so tell me im wrong people i wont mind (rather tightun some bolts then fug with tranny.. paps
Posted on: 2008/1/19 19:52
1028 Posts
aint checked c beam yet...but its ony in 3rd that ya can feel the very light shimmy (id call it) im ganna go wid worn 3rd er shift fork...3rd seems to be the most used gear fer my arears speed limits... ifn hold shifter faward its more noticable...
Posted on: 2008/2/2 18:03
the shifter itself can wear... so you might be getting some of that.
A loose c-beam, in this case, would cause a side to side rocking. The c-beam is mounted to the side the transmission, and bolted up vertically.
If it goes loose, the first symptom is a side to side rocking. If it's REALLY loose, then it would result in the up down motion you are expecting. But if it was that loose, there would be all sorts of wacky sounds and clunks.
Posted on: 2008/2/2 18:17
1028 Posts
i hear ya bog n i agree...ifn spring will ever arrive ill git ta find out more...hopefully by enjoyun the dayum thing!!!
Posted on: 2008/2/3 2:23
