253 user(s) are online (183 user(s) are browsing Forums)
matts85vet what causes intake backfire?
Toledo, Ohio
58 Posts
and how do i fix it?
im getting some off-idle backfiring through the intake and im trying to figure out what i can do to fix it.
thanks in advance
Posted on: 2010/11/11 21:02
85 coupe, 383, TPIS Miniram, auto 700R4, 3.75 gears, afr 180 eliminator heads 58cc, 12:1 compression ratio, comp cams 280XFI hydraulic roller cam, 1.65 roller rockers, 52mm throttle body, c5 calipers, hedman elite longtube headers, pypes dual exhaust w/x-
383tpimachine Re: what causes intake backfire?
Corpus Christi
976 Posts
timing.
Posted on: 2010/11/11 21:11
1970 El Camino-Awaiting LSX
CentralCoaster Re: what causes intake backfire?
valve timing or a bent valve?
Posted on: 2010/11/12 3:28
rklessdriver Re: what causes intake backfire?
What causes backfiring thru the intake manifold is the spark plug firing the A/F mixture when the intake valve is still open....
That can be caused by extremely low base ignition timing or a bent intake valve or an improperly adjusted intake valve (lash too tight).
Posted on: 2010/11/12 14:20
joeld Re: what causes intake backfire?
Check for any spark plug wires "jumping fire". Also check the distributor cap for small hair line crack inside, and for carbon tracking.
Posted on: 2010/11/12 15:39
tpi421vett Re: what causes intake backfire?
Salt Lake City Utah
125 Posts
A intake valve hanging open would be the most common cause as mentioned. On flat tappet engines, if it pops back thru the tb at full throttle, the cam is going flat. And if the engine is extemely cold and the A/F ratio is was lean, they can pop back thru the carb or tb when cold. And also ignition problems as mentioned
Posted on: 2010/11/13 7:04
08 C6 LS3,3LT,Z51,A6,NPP
450ci now with AFR 235...
blr33439 Re: what causes intake backfire?
9 Posts
How old is the distributer and cap. I had a similar problem on an 84 and it ended up being a bad distributer. Ran great after that.
Posted on: 2010/11/19 20:18
Tech Re: what causes intake backfire?
25 Posts
If it also has trouble at WOT it can be a week ignition/ low voltage. It takes more energy to fire at higher compression pressures.
If it does it at all rpms it can be the valve train. It is a fixed relationship. Has it been over reved?
A carbon tracked cap will usually have issues at all rpms.
Arcing plug wires sometimes show up in the dark.
If it sputters like you need a new accelerator pump when you give it a little gas but runs fine if you punch it, it can be a worn throttle position sensor with a flat spot in it.
Tech
Posted on: 2010/11/20 6:23
93 Corvette
The first Chevy that I have ever owned
