275 user(s) are online (226 user(s) are browsing Forums)
Ramrod What Not To Do?
S. California
296 Posts
Most forums tell you what and how to make repairs, ever thought of a "What Not To Do" like don't let your GF/Wife help you bleed brakes, Don't Drink beer and watch football while your testing electronics.
Posted on: 2008/1/21 4:59
dan0617 RE:What Not To Do?
Don't forget to remove the drip tabs from the valve covers when installing 1.6 rockers unless turning your pushrods into fishing hooks was your ultimate goal.
Posted on: 2008/1/21 18:27
pianoguy RE:What Not To Do?
Let's imagine that you're just a dumb-assed kid trying to muck around with the timing and idle on your old Grand Prix, having it in gear with the parking brake on, and the parking brake decides it's finally had enough of that crap, so the car starts creeping forward toward your future father-in-law's newly-painted garage door, and you're too brain-dead to just pull the coil wire to kill it. Well, if that happens, don't stand in front of the car trying to push back like Superman, because it just won't work.
Posted on: 2008/1/21 18:53
Also, if you're a dumb-assed kid with a frozen lug-nut, do not prop up the wrench on a piece of wood and hit it really hard with a hammer, otherwise the wrench could fly up and break your glasses right in 2.
Posted on: 2008/1/21 18:55
j3studio RE:What Not To Do?
Wow ...
Ramrod RE:What Not To Do?
S. California
296 Posts
Don't ever, never, flush out your transmission fluid after drinking too many beers! Especially when you pour the trans fluid into the oil pan.
1.) You overfill the oil pan.
2.) You have to drain the new oil & filter you just put in.
3.) You feel like an Idiot (because you are)
4.) For the love of God don't tell anyone!
Posted on: 2008/1/21 19:41
Notorious RE:What Not To Do?
When removing a stuck piston from a caliper with compressed air, never hold onto the piston with your other hand. Unless of course for some reason you actually enjoy having the top of a finger sewed back on......
Posted on: 2008/1/21 22:09
I hate sporks...
pianoguy, you are one brave soul for posting that first one. Sorry if your outcome was injury, but not knowing, I laughed hysterically when I read your posts.
Posted on: 2008/1/22 0:33
I learned a lot of painful lessons as a teenager (pride more seriously injured than body, thankfully)
When I was a kid, I had to work on my car out of necessity. My C4 is the first car I've had in decades that I've been interested in working on
Posted on: 2008/1/22 1:05
CFI-EFI RE:What Not To Do?
Top of Utah
372 Posts
Or in a similar scenario, rather than have the p brake fail, after the timing is set, the idle mixture screws adjusted to perfection, and it idles like a fine Swiss watch, you decide to blip the throttle in celebration of a job well done.
RACE ON!!!
Posted on: 2008/1/22 1:35
RACE ON!!!
Damn!
I must confess, my stupid stuff (with Corvettes) is not nearly as spectacular ...
Posted on: 2008/1/22 2:15
RACE ON!!!
OOH NO!! What was the outcome??
Posted on: 2008/1/22 18:38
