238 user(s) are online (207 user(s) are browsing Forums)
-=Jeff=- Help with a door panel
Bartlett, IL
573 Posts
I need to do something to allow sound through a door panel
Here is the area (back side) I need it to be
here is the front:
Any ideas on how to make it work? I just need this to be some sort of grill area
Posted on: 2010/12/31 3:05
-=Jeff=-
1990 Corvette ZR-1 #1051
bogus Re: Help with a door panel
wow... I hate those later door panels...
You can try to eat up the plastic from the inside, leaving the vinyl... then using a punch and awl, put some holes into it, then reback it with screen material to give it strength.
Does that make sense?
Posted on: 2010/12/31 3:17
Matatk Re: Help with a door panel
Do you want to cut the door panel? Or leave it looking the shape it's in?
Posted on: 2010/12/31 3:49
-=Jeff=- Re: Help with a door panel
Bartlett, IL
573 Posts
Yes, thought of that but concerned of the vinyl not being pliable enough (partly due to the age)
I could cut it as long as it would look good once done
Posted on: 2010/12/31 3:54
-=Jeff=-
I suspect the vinyl will survive... it will just be tricky...
Posted on: 2010/12/31 4:21
How big does the speaker opening need to be? Off the top of my head, I think you could use a cardboard tube (heavy duty) and cut out the circle, insert the tube and fiberglass it in, then wrap in vinyl and cover with a grill. Does that make sense the way I typed it? It's a lot of work, but I know that doesn't scare you
Posted on: 2010/12/31 12:35
Bartlett, IL
573 Posts
speaker in the door is 6.5" and will be doing mid-bass duty only. due to the dash it is partially blocked BUT, there is a cavity between the door panel and door, I am leaving the speaking in the doors themselves, so I could even do a 4" DIA grill in that area. I need to see how the 4" grill would work too.
I was not looking into doing something too complex if I can avoid it.. also not sure how to keep the vinyl from curling on the edges after cutting. While is might not happen right away it could still happen
Posted on: 2010/12/31 13:59
-=Jeff=-
The other option is to go totally off the deep end. Build the pod like I did (and Matt suggested) then wrap the entire panel in fresh vinyl, or even leather. At this stage, even something like Alcantara could be integrated.
Posted on: 2010/12/31 18:12
Bartlett, IL
573 Posts
yeah looking at the panels I have, the ribs are broken in a couple spots.. need to fix that and still work through what to do..
They will not be going on the car this year like I thought
Posted on: 2011/1/3 5:52
-=Jeff=-
Here is the score... remember the speaker pod I made with the Jag speaker grill and bezel? That took about 3 hours to make, with about 48 hours wall time, waiting for things to dry/set.
It won't take much to fix and modify the panels.
Posted on: 2011/1/3 7:49
Bartlett, IL
573 Posts
yeah I know. but for some of the stuff (fibeglassing) I need to wait until it is warmer here first
Posted on: 2011/1/3 13:29
-=Jeff=-
CentralCoaster Re: Help with a door panel
I'm not sure of a way to perforate the vinyl without it looking uneven and crappy. Maybe mark grid lines on it in a hex pattern with something removeable, then peel the vinyl off and use a leather punch against a wood board behind it. Then mark and do the same holes in the plastic behind it, remove whatever padding is in there, then reinforce the plastic or vinyl if necessary.
Posted on: 2011/1/3 20:14
Bartlett, IL
573 Posts
Need to look at this again due to the new door configuration with my door locks
So I am thinking a 4" round grill just to let the midbass sound through.. I will try to get a pic of what I am thinking
Posted on: 2011/1/27 3:46
-=Jeff=-
Bartlett, IL
573 Posts
Now that I need to get these working for the car.. I was looking around for some grills to try and found some that will work perfectly and are flexible (to a point)
I will cut out holes in the doors for these and cover the grills in grill cloth. I also have to add a few pieces for mounting them but I think this is a perfect/not too complex solution:
left side is fairly easy:
Passenger side while a bit harder with this grill it will be much better and I already have the grill contour close tot he panel:
Posted on: 2011/1/27 12:56
-=Jeff=-
That has possiblities!
Posted on: 2011/1/27 20:36
Looks good so far! You might have to secure the grill using a bolt/nut on the back. I'm not sure if there will be enough bite in just the panel itself.
Posted on: 2011/1/28 3:14
Bartlett, IL
573 Posts
That is the plan
Passenger side is cut.. working on driver side
Posted on: 2011/1/28 3:22
-=Jeff=-
Bartlett, IL
573 Posts
Driver side cut:
Passenger side
Posted on: 2011/1/28 4:01
-=Jeff=-
Awesome. For my car I just got some fabric at JoAnnes...basic black cloth...they didn't have "speaker fabric" specifically, but I only paid like 3-4 dollars for a yard or two.
Posted on: 2011/1/28 12:30
Bartlett, IL
573 Posts
I have a bunch of black grill cloth I bought from parts express a couple years ago. I just need to buy some hardware for mounting them
Posted on: 2011/1/28 12:50
-=Jeff=-
Bartlett, IL
573 Posts
Another update..
[IMG width=300]http://lh3.ggpht.com/_N1g6599TmMo/TUR7pJ3OS_I/AAAAAAAABhk/7ryZpEXgxx0/s800/2011-01-29_14-28-42_90.jpg[/IMG]
Posted on: 2011/1/29 20:55
-=Jeff=-
flyboy Re: Help with a door panel
Nice work. So, the speaker is nearby but not directly behind the grill?
Posted on: 2011/1/29 21:17
Bartlett, IL
573 Posts
yes that is correct. Should work well, if not I can change it
Posted on: 2011/1/29 21:25
-=Jeff=-
I think it looks great and should work out well.
Posted on: 2011/1/30 12:36
Bartlett, IL
573 Posts
Posted on: 2011/1/31 0:35
-=Jeff=-
Impressive!!! I like that. It really overcomes the limitations of the door panels, very nicely!!!
Posted on: 2011/1/31 0:45
Bartlett, IL
573 Posts
Thanks Bogus!.. Funny thing it was not to complicated to do, that grill I used is a OEM Corvette part too.
Posted on: 2011/1/31 0:48
-=Jeff=-
Gotta love a job well done! And one that was CHEAP to do!
How does it sound? That fabric looks shear enough to not block sound.
Posted on: 2011/1/31 0:54
Bartlett, IL
573 Posts
Um sound?
no clue,. system is not wired yet and the new HU is not installed
this was done to finish the Window regulator replacement
Posted on: 2011/1/31 0:55
-=Jeff=-
Looks factory. What year corvette was the grill from?
Posted on: 2011/1/31 12:56
Bartlett, IL
573 Posts
90-96 Rear Bose 6.5 speaker grill. under the interior matched grill
Posted on: 2011/1/31 12:59
-=Jeff=-
Tre57 Re: Help with a door panel
Portland, OR
104 Posts
That looks nice! Makes me wish I hadn't disposed of my rear inner grills.
Question: How are the speakers mounted? I am about to rip out all the interior (again) to install an amp and want to get rid of the 4's in kick panels and mount some 5.25 components in the doors.
Posted on: 2011/2/28 10:09
93 AT Coupe
Bartlett, IL
573 Posts
the speaker are mounted to the door themselves. not optimum, but the speakers in the doors are just midbass
Posted on: 2011/2/28 13:06
-=Jeff=-
Portland, OR
104 Posts
Thanks. I will check the doors for place to mount the mids when I get the panels off.
Posted on: 2011/3/1 8:00
Bartlett, IL
573 Posts
Someone asked about sound
well.. the 6.5" sound great, the rest is well.. meh
I REALLY need to go active, I have the nak in there due to noise from the Eclipse. Active sounded good, so I am thinking of looking at the MiniDSP again.. then I don't need a 3-way headunit.. but I will deal with the system for the summer
Posted on: 2011/4/21 3:07
-=Jeff=-
